L757 Posted January 14, 2020 Share Posted January 14, 2020 HiI have an old Mainline class 45 diesel that I have found on forums to be an easy dcc conversion . There is just the two wires. They recommend a Bachmann or Zimo decoder I have the select controller, I have read there are issues with this and non Hornby decoders so would the new Hornby R2724 be a good choiceThanks Link to comment Share on other sites More sharing options...
Howbi Posted January 14, 2020 Share Posted January 14, 2020 I presume you mean the R7274 4-pin decoder..........no reason why this can't work, just have to cut off the plug, unsolder the 2 wires to the motor and connect them to the red & Black then join the orange & grey from the decoder to the motor........don't forget heatshrink on the joins and test it runs in the same direction as selected on the controller before re-fitting the top..........however, you should consider fitting an 8-pin socket to future proof the operation. This would enable you to install running lights at some stage and give you a better choice of 8-pin plug&play decoders..........HB Link to comment Share on other sites More sharing options...
Chrissaf Posted January 14, 2020 Share Posted January 14, 2020 R2724 is a loco......did you mean the R7274 (pre-order)..The R7274 is just a standard R8249 decoder with the 8 Pin plug removed and fitted with a 4 way connector instead..EDIT: HB beat me to it this time. Link to comment Share on other sites More sharing options...
L757 Posted January 14, 2020 Author Share Posted January 14, 2020 Thanks. I have actually bought a harness but was thinking of the small decoder due to its current limitations. I will consider the normal 8 pin for the future. Thanks again Link to comment Share on other sites More sharing options...
