Sumplug Posted January 18, 2020 Share Posted January 18, 2020 i have just had my select updated by Hornby and I have reprogrammed my locos but they only run for about a minute and they stop with a error code of EO on the select controller. This happens if I have one loco on the track or three Link to comment Share on other sites More sharing options...
96RAF Posted January 18, 2020 Share Posted January 18, 2020 EO stands for Emergency Off denoting an Overload as explained in the notes that will have come with your updated Select (Extract below). In this state the track power is turned off, indicating that there is probably a short somewhere. Check your track and look to see if its any loco causing it - or if its the same loco causing it. Is there a point set wrong or faulty. ES stands for Emergency Stop . In this state all locos are told to stop but power remains on track, such as when you hit the STOP button to prevent a crash. You can initiate either of these states by a short push on the STOP button (ES) or a long push (EO). /media/tinymce_upload/6966a71dc1c26f5f25ea38c35bcfcdd4.png Link to comment Share on other sites More sharing options...
Sumplug Posted January 18, 2020 Author Share Posted January 18, 2020 Thank you, i will check the track and the locos Link to comment Share on other sites More sharing options...
