David55 Posted March 17, 2012 Share Posted March 17, 2012 I have just got a new class 37 from B.I set this up on the elite and switched on functions 1 & 2. However when I put the train on Railmaster it says that I am putting in functions that I have not set up on the controller. These are clearly shown on the elite.Any Idea's. Link to comment Share on other sites More sharing options...
wiggy25 Posted March 17, 2012 Share Posted March 17, 2012 You've set the functions up on the Elite but not in RailMaster, you need to do this in RailMaster as well.In RailMaster, bring up the locomotive list from the icon at the top of the screen.Select the loco you want to set up from the list of locos and at the bottom of the window just off the center there is an icon that looks like two arrows in a circle, by pressing this brings up default sets of functions, steam, diesel 1 and diesel 2 which are default set ups, normally for sound locos with lots of functions.Or you could just select the loco, then in the functions area click in the drop down box to select which functions you want on that function number then put a tick in the little box next to this.Click on the tick to accept changes.When you go to the main screen and select that loco for control you should now be able to operate the functions you've just assigned.CheersIan Link to comment Share on other sites More sharing options...
David55 Posted March 19, 2012 Author Share Posted March 19, 2012 Thanks for your reply.Forgot to put a tick in the little box. It now works.CheersDave Link to comment Share on other sites More sharing options...
