Michael_A Posted March 18, 2020 Share Posted March 18, 2020 I have a loco with an old 8215 decoder fitted which runs perfectly well on DCC, CVs can be changed etc. However the loco does not run on DC, and as far as I know, there is no CV to change that. Can anyone help. Link to comment Share on other sites More sharing options...
96RAF Posted March 18, 2020 Share Posted March 18, 2020 As you can see here R8215 is permanently enabled for DC running, which is why you do not have the option to change it In CV29. Note also may be awry due to bit 7 default set to on in the factory. /media/tinymce_upload/4d62ec56469992840bafb30248a98297.png Link to comment Share on other sites More sharing options...
Michael_A Posted March 24, 2020 Author Share Posted March 24, 2020 Having issue.Thanks for the reply. I know all that, my point is I can't change it and it won't run on DC, so I assume there is nothing I can do /chip is faulty? Link to comment Share on other sites More sharing options...
96RAF Posted March 24, 2020 Share Posted March 24, 2020 The reason R8249 superseded R8215 is because they were not a reliable decoder. Best place for them is in the bin. Link to comment Share on other sites More sharing options...
Flashbang Posted March 24, 2020 Share Posted March 24, 2020 I have to agree with RAF96. A very poor decoder!However, CV29 set to a value of 6 will usually allow DC operation. If your DCC system (you havent mentioned what it is?) can read CVs then read CV29 before starting and note it down, then add 4 to whatever was read which should turn on DC operation. This on line CV29 calculator is very helpful http://www.2mm.org.uk/articles/cv29%20calculator.htm While its to the 2mm Association, CV29 setting is the same regardless of scale. Link to comment Share on other sites More sharing options...
96RAF Posted March 24, 2020 Share Posted March 24, 2020 R8215 has DC running bit set to on fixed as default. You shouldn’t be able to write a value that disables it. Link to comment Share on other sites More sharing options...
Michael_A Posted March 29, 2020 Author Share Posted March 29, 2020 I have a Hornby Elite. CV29 cannot be read, and writing 06 to it makes no difference, though if I write 03 it does change direction.Not the end of the world I guess, I just like to run my rolling road for wheel cleaning and maintenance from a PP3 battery or my HM2000 rather than connect it to DCC. Link to comment Share on other sites More sharing options...
96RAF Posted March 29, 2020 Share Posted March 29, 2020 A couple of snippets of info I found in my files . .Very early R8215s could not be interrogated at all. Later versions could be interogated but only in Reg programming mode.Some versions were not compatible with Elite Standard mode, so try it in Classic mode and also interogate in Reg mode. Link to comment Share on other sites More sharing options...
