FrankIsWFH Posted March 18, 2020 Share Posted March 18, 2020 Just trying out my J36 on a test rig using my old Dynamis EzCommand with Pro Box. Blimey it's loud!One (fairly major) problem. I can't seem to get the "chuff" sound to work - as you turn on some speed I get the startup sound, but no chuff whatsoever - it just seems to go straight to what I assume is the "cruise" sound. The F17 toggle doesn't make any difference. Any ideas? Link to comment Share on other sites More sharing options...
96RAF Posted March 18, 2020 Share Posted March 18, 2020 Try a decoder reset by writing either value 5 (sound only) or value 8 (total reset) to CV8, if the EZ supports writing to CVs. The other things to look at (controller dependant) are:Are you on 128 speed stepsAre CVs 3 & 4 set to a minimum value of 15. Link to comment Share on other sites More sharing options...
FrankIsWFH Posted March 18, 2020 Author Share Posted March 18, 2020 Try a decoder reset by writing either value 5 (sound only) or value 8 (total reset) to CV8, if the EZ supports writing to CVs. The other things to look at (controller dependant) are:Are you on 128 speed stepsAre CVs 3 & 4 set to a minimum value of 15.Tried all these, still no joy. As you head off, it does the steam exhaust, but still no "chuff". I wonder if it's a command station problem, rather than decoder. Link to comment Share on other sites More sharing options...
96RAF Posted March 18, 2020 Share Posted March 18, 2020 We won’t know that until you try it with another make controller. Any chance you could visit a local model shop or model railway club to confirm. At least then you know where the problem is. BTW - Hornby does test it’s decoders with a wide range of other make DCC controllers, same as it tests it‘s DCC controller firmware updates with a wide range of other make decoders, you could maybe ask HCC if they could checkwith R&D if Dynamis is one of those. Link to comment Share on other sites More sharing options...
96RAF Posted March 18, 2020 Share Posted March 18, 2020 Something just sprung to mind. You say you are testing on a test rig. Does this test rig have a motor as steam TTS needs bemf from the motor turning to work the chuffs correctly. If not then you will not get a chuff only the cylinder blow down. I can confirm this as I had my Coronation tender only on the new layouty as a test mule and although everything else worked from a sound viewpoint there was no chuff on throttle up as there was no loco to provide bemf. Link to comment Share on other sites More sharing options...
FrankIsWFH Posted March 19, 2020 Author Share Posted March 19, 2020 Something just sprung to mind. You say you are testing on a test rig. Does this test rig have a motor as steam TTS needs bemf from the motor turning to work the chuffs correctly. If not then you will not get a chuff only the cylinder blow down. I can confirm this as I had my Coronation tender only on the new layouty as a test mule and although everything else worked from a sound viewpoint there was no chuff on throttle up as there was no loco to provide bemf.Genius thought! I was on the Merg test rig, will install in a loco and have another go. Thanks again! Link to comment Share on other sites More sharing options...
Chrissaf Posted March 19, 2020 Share Posted March 19, 2020 Frank, Can I please bring TIPs 1, 2 & 3 of my 'How to get the best from this forum' page to your attention. There is no real need to keep using the 'Blue Button' to re-quote the post directly above your own. The 'Blue Button' is not a 'Reply to this post' button. Link to comment Share on other sites More sharing options...
FrankIsWFH Posted March 19, 2020 Author Share Posted March 19, 2020 it works! Link to comment Share on other sites More sharing options...
96RAF Posted March 19, 2020 Share Posted March 19, 2020 That’s good. Another satisfied customer. For info Hornby has a Dynamis but not the ProBox which I believe is to enable service mode programming. Also for info a diesel TTS would have worked on your test rig as it does not rely on BEMF. You may lime to look at hanging a motor on your Merg rig. Link to comment Share on other sites More sharing options...
