Chrissaf Posted March 23, 2020 Share Posted March 23, 2020 Hi All i am on E Link some of my Locomotives with tts sound are starting up on there own when. the E Link has been turn on for a time i have not toll them to start. any i dears. thank Ron. Link to comment Share on other sites More sharing options...
Chrissaf Posted March 23, 2020 Share Posted March 23, 2020 Check your power connectors on the track to ensure that they are not DC Analogue versions. Remove any capacitors that you find in any DC Analogue versions that you have on the layout../media/tinymce_upload/791adac1fb1bfa0b8aabb3813cc97b38.jpg. Link to comment Share on other sites More sharing options...
ron 47 Posted March 23, 2020 Share Posted March 23, 2020 HI all the rail power wiers are solderd to the track and Hornby power boster in line.thank Ron 47 Link to comment Share on other sites More sharing options...
96RAF Posted March 23, 2020 Share Posted March 23, 2020 How is your booster connected. Can you post a diagram of the wiring and where it is connected to.How big is your layout that it needs a booster. Link to comment Share on other sites More sharing options...
jane1707819582 Posted March 23, 2020 Share Posted March 23, 2020 HI all the rail power wiers are solderd to the track and Hornby power boster in line.thank Ron 47Hi Ron .I too have experienced this ,I use a different controller ,No booster and soldered connections.Which loco's have you had issues with ?.the fault has now cleared itself the only thing I have done is to take the loco off the track for a while . Link to comment Share on other sites More sharing options...
96RAF Posted March 24, 2020 Share Posted March 24, 2020 What kind of a power bus do you have if any, or it just the controller feeds soldered to the rails. I saw similar behaviour when I had a single feed to a triple loop circuit with thin jumper wires between loops. Link to comment Share on other sites More sharing options...
