Shane63 Posted March 30, 2020 Share Posted March 30, 2020 I have a unique situation. My DCC equipped engine runs on the programming track, but has stopped working on the main track. My other engines work with no problem.Any help will be greatly appreciated. Link to comment Share on other sites More sharing options...
96RAF Posted March 31, 2020 Share Posted March 31, 2020 Which controller are you using? Which loco and which decoder is fitted if known. Programming track output normally does not have enough oomph to run a loco. It may twitch or flash the lights as an acknowledgement but won’t respond to normal running commands. The only exceptions are controllers such as the Select which only have a Track output and although they program in service mode it is essentially on the main. If your controller supports it can you program that loco on the main (POM). Link to comment Share on other sites More sharing options...
jane1707819582 Posted March 31, 2020 Share Posted March 31, 2020 Can / Have you reset the decoder .then try it on your main track address 3 . Link to comment Share on other sites More sharing options...
Chrissaf Posted March 31, 2020 Share Posted March 31, 2020 As Rob (RAF96) says, you have to tell us which controller you are using..If it is the Select, there is no technical difference between a 'programming' track piece and the main layout track. They both physically connect to the same terminals on the Select. The only difference is that the Select 'programming' track piece is usually short and physically isolated from all other DCC kit that have decoders in it.. Link to comment Share on other sites More sharing options...
Shane63 Posted March 31, 2020 Author Share Posted March 31, 2020 Which controller are you using? Which loco and which decoder is fitted if known. Programming track output normally does not have enough oomph to run a loco. It may twitch or flash the lights as an acknowledgement but won’t respond to normal running commands. The only exceptions are controllers such as the Select which only have a Track output and although they program in service mode it is essentially on the main. If your controller supports it can you program that loco on the main (POM).Hi, I am using a Z21 with a Hornby Class 20 diesel. All other engines (Hornby) are working fine, so it is not a problem with the main track. I have also tried them on the programming track and there is no problem. Link to comment Share on other sites More sharing options...
96RAF Posted March 31, 2020 Share Posted March 31, 2020 You might want to have a look on RM Web DCC forum where Z21 gets a lot of discussion recently. Is the Class 20 fitted with a TTS decoder or a standard decoder. If TTS try turning it round on the programming track annd see if that works. It may be if a TTS decoder it needs its firmware updating. Link to comment Share on other sites More sharing options...
Shane63 Posted April 1, 2020 Author Share Posted April 1, 2020 You might want to have a look on RM Web DCC forum where Z21 gets a lot of discussion recently. Is the Class 20 fitted with a TTS decoder or a standard decoder. If TTS try turning it round on the programming track annd see if that works. It may be if a TTS decoder it needs its firmware updating. Thank you. Link to comment Share on other sites More sharing options...
