Chrissaf Posted April 5, 2020 Share Posted April 5, 2020 Hi welcome to the site.What you are asking is called asymetric control.See this article for info. https://dccwiki.com/Asymmetric_DCC Link to comment Share on other sites More sharing options...
96RAF Posted April 5, 2020 Share Posted April 5, 2020 The basic BM1 modules are easy to make yourself as they are a simple 5-diode loop.see here ...http://www.halton96th.org.uk/page33.html ... noting that it works best with fast switching diodes and you need an ADCC/ABC compatible decoder. You can also do it in software such as Railmaster, JMRI, Rocrail, iTrain, etc. Link to comment Share on other sites More sharing options...
Chrissaf Posted April 5, 2020 Share Posted April 5, 2020 TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
Chrissaf Posted April 5, 2020 Share Posted April 5, 2020 Hello,As a relative newcomer please could anyone advise me on whether it is possible with DCC to vary the speed (power) going to a loco so that it accelerates / decelerates at specific locations on the track and then retains this pattern throughout the route? In other words, so that it repeatedly slows when approaching and passing through stations or accelerates (increases power) when ascending or reduces power when descending. If this is possible, which DCC controller would you recommend? Thank you Link to comment Share on other sites More sharing options...
96RAF Posted April 5, 2020 Share Posted April 5, 2020 There is also an active topic about it here...https://www.rmweb.co.uk/community/index.php?/topic/131595-abc-braking/ Link to comment Share on other sites More sharing options...
Low Mill Posted April 5, 2020 Share Posted April 5, 2020 Thank you all very much Link to comment Share on other sites More sharing options...
