Spider323 Posted April 26, 2020 Share Posted April 26, 2020 HiI have recently started using Railmaster again and on setting up installed the latest update. However, having done so the Hornby Points Decoder continues to activate Point 1 on each decoder. It clicks continuously one way. many thanks Link to comment Share on other sites More sharing options...
Chrissaf Posted April 26, 2020 Share Posted April 26, 2020 There are no other reports of this issue that I am aware of, and I take an interest with regards all issues that are RailMaster related..You say started using RM again .... that infers that you have been using a different controller prior to this issue..Please provide a little more background information ... such as:.When all was working OK what controller were you using then?Have you ever used RM successfully ... why did you stop using it?What are you using with RM now, with this issue ... eLink or Elite?Do you get any on screen controller related error messages ... are your RM to controller connections stable?.If you get any RM to controller communication issues or error messages or drop-outs then I suggest running through the guidance in this recent thread relating to the new 1.7 RM software release..https://www.hornby.com/uk-en/forum/adding-the-hornby-r8213-dcc-select-controller/?p=1.TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
Spider323 Posted April 26, 2020 Author Share Posted April 26, 2020 No changes since last use Albeit some 9 months ago. Same controller -Elite. No issues whatsoever until update. No controller related error messages. Link to comment Share on other sites More sharing options...
Chrissaf Posted April 26, 2020 Share Posted April 26, 2020 A complete new issue to me. I have no suggestions to make, apart from going through the guidance in my link anyway just in case. Other than that, the only other thing you can do is use the integral 'support request' in the 'Help Screen' and document / report your issue to HRMS (Hornby RailMaster Support). Link to comment Share on other sites More sharing options...
96RAF Posted April 27, 2020 Share Posted April 27, 2020 It sounds like RM set points on startup sub routine is stuck in a loop.If you can deselect set points on startup, shut down and restart RM and report back.If that stops the repeating action, then try selecting set on start up again, shut down and restart RM again. The outcome of these actions will add information to your report to HRMS. Link to comment Share on other sites More sharing options...
Spider323 Posted April 28, 2020 Author Share Posted April 28, 2020 Good News. I dug out an old laptop with Railmaster installed and ran on 1.68 and no problems. Installed latest upgrade and again no problems. Will continue to investigate with previous laptop and let you know of outcome if any.Again many thanks for your prompt replies and help.Stay safe.Regards Link to comment Share on other sites More sharing options...
96RAF Posted April 28, 2020 Share Posted April 28, 2020 Compare ini files on old and new laptops. Link to comment Share on other sites More sharing options...
