JakeDoesGamez Posted May 3, 2020 Share Posted May 3, 2020 So I've just been finishing my model rail after a year long hiatus and I mainly use an E-Link system, but it takes ages to setup and for a quick test it's just better to use my old DCC Select. I've been running my layout for a while (locos, points and signals) when I look down on the DCC Select and there is an error code and the red LED in the top left flashing. I perceived the error code to be CE. aI unitunplugged and replugged the unit and tried again. This time it ran for about a minute before it did it again. Does anyone know what this means, so that I can try and fix it.Cheers, Jake Link to comment Share on other sites More sharing options...
Rog RJ Posted May 3, 2020 Share Posted May 3, 2020 There is a list of error messages in the back of the user manual. CE is command error from Expressnet LA Locomotive Address.AC AccelerationdE DecelerationFd Forward Directionrd Reverse DirectionE5 Emergencey StopA1 Consist Address 1A2 Consist Address 2CA Clear AllON You have turned "ON" a functionoF You have turned OFF a functionC5 Control StationHC Hand ControllerH5 Speed Step 128CE Command Error from XpressNetOL Short circuit or overloadLCDPlease see Trouble Shooting for full details Link to comment Share on other sites More sharing options...
Chrissaf Posted May 3, 2020 Share Posted May 3, 2020 Can you confirm that when you use the Select for testing purposes, that you physically remove the eLink track output connection from the track..It would also be helpful to know what firmware version is installed on your Select. What is the very first number to appear briefly on your LCD screen when the Select is powered up. Expect to see a number between 10 and 20..TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
96RAF Posted May 3, 2020 Share Posted May 3, 2020 The error code suggests the Select is being used as a Walkabout but you do not mention it being plugged into a master controller by way of an RJ cable, so how is it connected. Link to comment Share on other sites More sharing options...
Chrissaf Posted May 3, 2020 Share Posted May 3, 2020 He mentions eLink which would seem to discount 'Walkabout', but of course the eLink might be a 'typo' and should read 'Elite'. Link to comment Share on other sites More sharing options...
