L757 Posted May 6, 2020 Share Posted May 6, 2020 Hiive just replaced an old mainline warship with a new Bachmann 43 warship but hope to use a hornby decoder chip to try and minimise possible issues. I have a select controller. Any suggestions would be appreciated Link to comment Share on other sites More sharing options...
2e0dtoeric Posted May 6, 2020 Share Posted May 6, 2020 You need an adapter. Hornby use 8 pin decoders, Bachmann use 21 pin. Link to comment Share on other sites More sharing options...
Flashbang Posted May 6, 2020 Share Posted May 6, 2020 If your Select is at Firmware V1.6 or 2.0 (As shown on the display at start up by the first pair of digits) then there shouldn't be any issues. If it shows anything else from example 1.1 to 1.5 I would recommend that you consider contacting Hornby and arrange for it to be returned and upgraded. Note you must obtain a returns number before sending it back. I understand the cost is (or was) £15 but that should be confirmed by Hornby when contacted.There are many other makes of decoder with 21 pin fittings available too! Link to comment Share on other sites More sharing options...
96RAF Posted May 6, 2020 Share Posted May 6, 2020 £15 + vat = £18. Link to comment Share on other sites More sharing options...
L757 Posted May 6, 2020 Author Share Posted May 6, 2020 If your Select is at Firmware V1.6 or 2.0 (As shown on the display at start up by the first pair of digits) then there shouldn't be any issues. If it shows anything else from example 1.1 to 1.5 I would recommend that you consider contacting Hornby and arrange for it to be returned and upgraded. Note you must obtain a returns number before sending it back. I understand the cost is (or was) £15 but that should be confirmed by Hornby when contacted.There are many other makes of decoder with 21 pin fittings available too! are you suggesting that with a firmware update it will cope with a Bachmann chip Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 6, 2020 Share Posted May 6, 2020 L757, please don't use the blue button to reply,scroll to the bottom of the page and use the text box and green reply button. Then you've compounded the error by putting your own text in the yellow box too, many will miss it. The answer is yes, Select with latest firmware should cope with all decoder brands, including Bachmann. Link to comment Share on other sites More sharing options...
Sultan Posted May 7, 2020 Share Posted May 7, 2020 I would avoid using a 21 pin to 8 pin converter as they can cause fitting issues with the extra height above the socket sometimes making it hard to fit a decoder.Instead I would look at any of the following 21 pin decoders:Lenz Siver+ 21pinDCC Concepts Zen Black ZN218Zimo MX638D Link to comment Share on other sites More sharing options...
L757 Posted May 7, 2020 Author Share Posted May 7, 2020 Thanks for the help and advice to all Link to comment Share on other sites More sharing options...
