PDW Posted May 24, 2020 Share Posted May 24, 2020 Good day - using Railmaster Pro latest version, Microsoft Surface, Windows 10 Pro and Elink.Have a Class 40 which I cannot seem to control the sound levels - following is the CV readings - you will see I have reduced most to low values - but sadly does not seem to make any difference - what do I need to do?CV Settings for loco: Class 40 TTS (ID: 0040)CV No. CV Name Value Result String1 Primary address 040 99 20 1 40 943 Acceleration rate 047 99 20 3 47 914 Deceleration rate 015 99 20 4 15 1247 Decoder chip version 127 Hornby TTS decoder8 Manufacturer ID 048 Hornby Hobbies Ltd.10 EMF feedback cutout 160 99 20 10 160 22117 Extended address 192 99 20 17 192 16618 Extended address 102 99 20 18 102 329 Decoder config 015 99 20 29 15 101150 Motor algorithm 048 99 20 150 48 209151 P1 motor algorithm 1 140 99 20 151 140 108152 I1 motor algorithm 1 008 99 20 152 8 231153 P2 motor algorithm 2 215 99 20 153 215 57154 I2 motor algorithm 2 243 99 20 154 243 30158 Loco type 033 99 20 158 33 200159 Sound mode 151 99 20 159 151 127161 F1 volume 002 99 20 161 2 150162 F2 volume 002 99 20 162 2 149163 F3 volume 001 99 20 163 1 213164 F4 volume 007 99 20 164 7 212166 F10 volume 002 99 20 166 2 145167 F11 volume 004 99 20 167 4 150168 F12 volume 009 99 20 168 9 214169 F13 volume 001 99 20 169 1 223170 F14 volume 001 99 20 170 1 220171 F15 volume 009 99 20 171 9 213172 F16 volume 002 99 20 172 2 155173 F17 volume 004 99 20 173 4 156174 F18 volume 001 99 20 174 1 216175 F19 volume 003 99 20 175 3 153176 F20 volume 005 99 20 176 5 194177 F21 volume 004 99 20 177 4 128178 F22 volume 004 99 20 178 4 131179 F23 volume 004 99 20 179 4 130180 F24 volume 011 99 20 180 11 200210 Trigger threshold 1 133 99 20 210 133 32211 Trigger threshold window 1 005 99 20 211 5 161212 Trigger threshold 2 031 99 20 212 31 188213 Trigger threshold window 2 005 99 20 213 5 167214 Trigger threshold 3 060 99 20 214 60 157215 Trigger threshold window 3 165 99 20 215 165 5Also, when I select this loco into the larger window I can only see 16 function buttons - as you can see there are actually 24 different sounds available - how can I see the other function buttons to trigger thier sound?Appreciate any help.Phil Link to comment Share on other sites More sharing options...
Chrissaf Posted May 24, 2020 Share Posted May 24, 2020 Also, when I select this loco into the larger window I can only see 16 function buttons - as you can see there are actually 24 different sounds available - how can I see the other function buttons to trigger thier sound?.This specific question has been asked and answered before. To see that thread click the link below:.Expanding the large throttle to see all function buttons. Note: since the reply in this thread was written, the function button display has been extended to show F26 to F28 as well (only up to F25 is documented in the link)..https://www.hornby.com/uk-en/forum/sound-functions-in-rm/?p=1.Additional info for questions not actually asked - well not yet anyway..“on/off” function button labelshttps://www.hornby.com/uk-en/forum/post/view/topic_id/19619/?p=2.Six function button error message.https://www.hornby.com/uk-en/forum/six-function-button-error-post-by-ianb/?p=1/. TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
96RAF Posted May 24, 2020 Share Posted May 24, 2020 Look in the .ini file and there is a line something like controller full = 0 . Make this = 1 and the expanded controller will show a 16 (?) button grid without having to use the red triangle expander. This grid can be dragged up and down to show all buttons. Sound levels - if you make master volume CV182 = 0 does the sound turn off completely. You would normally be able to do this using Operate programming mode (Prog on the Main) but eLink and RM does not support that mode. Note that master volume is not readable so that is why you cannot see that CVs value, but you can still write to it using RM. Some TTS decoders had a build fault and the master volume was offset by +2 so if CV182 doesn’t work try CV184. Link to comment Share on other sites More sharing options...
PDW Posted May 25, 2020 Author Share Posted May 25, 2020 Many thanks to you both - can happily now access all function buttons.You were right that CV 182 set to 0 mutes the audio. Have now set to '001' - have to say - still pretty loud - it would be good to reduce a little futher.I have set the other individual sound functions to 001, 002 or 003 - they are all still a tad loud.Any advice appreciatedPhil Link to comment Share on other sites More sharing options...
Chrissaf Posted May 25, 2020 Share Posted May 25, 2020 TTS are loud ... not much more than you have done already you can do about it. Link to comment Share on other sites More sharing options...
96RAF Posted May 25, 2020 Share Posted May 25, 2020 The standard TTS speaker is 8 ohms so you can wire another in series to make 16 ohms or if you want to really shush it install 100 ohm speaker but doing this risks having to wind the volume back up and overtaxing the decoder audio amp. Link to comment Share on other sites More sharing options...
PDW Posted May 25, 2020 Author Share Posted May 25, 2020 Many thanks Phil Link to comment Share on other sites More sharing options...
