Anton Stedman Posted June 10, 2020 Share Posted June 10, 2020 Hello,Is the wire used for connecting the controller to the track special? I ask because I have a relatively large layout and wanted to extend the length that the controller could move around. If it is not special could I just cut a longer length of wire?Thank you, Link to comment Share on other sites More sharing options...
Chrissaf Posted June 10, 2020 Share Posted June 10, 2020 Nothing special. It just needs to be thick enough to carry the expected current, plus a bit more as a safety margin. Link to comment Share on other sites More sharing options...
Anton Stedman Posted June 10, 2020 Author Share Posted June 10, 2020 Ok, that great. Would this wire be suitable... https://www.hattons.co.uk/43434/expo_drills_tools_22021_100m_drum_18_strand_cable_black_outside_diameter_1_0mm/stockdetail.aspx Sorry, dont know why this posted twice. Could an admin remove one of them... Link to comment Share on other sites More sharing options...
Flashbang Posted June 10, 2020 Share Posted June 10, 2020 Unfortunately the details provide in that link do not offer any actual wire size or its current carrying capacity! For a 4.0 Amp system I would look as a minimum using 24/0.2mm equipment wire (Sometimes called Hook up wire) and better would be 32/0.2mm Examples are shown here but there are of course other suppliers too https://www.brimal.co.uk/cable-wire.html Link to comment Share on other sites More sharing options...
Chrissaf Posted June 10, 2020 Share Posted June 10, 2020 I agree with F.B..18 strands is IMO too thin. 24 strands minimum or 32 strands preferred. Link to comment Share on other sites More sharing options...
96RAF Posted June 10, 2020 Share Posted June 10, 2020 Nip down Screwfix or Homebase and get a bit of much cheaper flexy twin core mains cable, or nick a bit off a table lamp at home. Link to comment Share on other sites More sharing options...
Anton Stedman Posted June 10, 2020 Author Share Posted June 10, 2020 Thank you, that is very helpful. I mentioned that particular wire because I have already got it but should easily be able to buy the ones you suggested. Thanks 😀 Link to comment Share on other sites More sharing options...
