Peckett Decoder help required
Mando
I fitted an R7274 4pin docoder to my 0-4-0 Peckett. The chip has been recognised and the engine renumbered but does not move forward or backward. I use an NCE Power Cab. Can anyone offer any suggestions, I'm fairly new to DCC.
Thanks
Did you test it on the default 03 DCC address first before trying to change the address?
Try running it on the default 03 address anyway. If the loco responds using address 03, then your attempt to change the address didn't work. Does the loco run OK on a DC supply? If it does, then that would indicate that the basic electrical installation is probably OK.
