Sir TophamHatt Posted June 25, 2020 Share Posted June 25, 2020 Fitted a Lenz Silver+ v2 but the headlamp is on all the time, even when I press the "lights" button on my PA2.Is it supposed to be on all the time?Is there a way that I can turn it on / off using the F1 function? Link to comment Share on other sites More sharing options...
Rog RJ Posted June 25, 2020 Share Posted June 25, 2020 Have you rewired the loco so that the light is switched by the decoder? It will probably be best to replace the bulb, if it is a bulb, with an Led and resistor. Link to comment Share on other sites More sharing options...
96RAF Posted June 25, 2020 Share Posted June 25, 2020 The basic design is on all the time. I doubt you will be able to simply modify it to switchable, without hacking PCB around. Is there a service sheet for it yet. Link to comment Share on other sites More sharing options...
ellocoloco Posted June 25, 2020 Share Posted June 25, 2020 The Hogwarts Castle with the light is marked as DCC ready so there should be no need for OP to rewire the loco.... I would expect the light to be switchable. Could the decoder be plugged in the wrong way round? Also you say its a Lenz Silver + V2 you are using or is it a Lenz Standard V2+? I though the Silver were 21pin and if so are you putting it through a 21-8 adaptor? (Edit: RAF added more info while I was typing...I assumed the HP loco would have its light wired like any other OO/HO model with lights) Link to comment Share on other sites More sharing options...
Going Spare Posted June 25, 2020 Share Posted June 25, 2020 Service Sheet 306 shows the Castle with a headlight but it is not very clear as to how the headlight is wired relative to the motor. Link to comment Share on other sites More sharing options...
Fishmanoz Posted June 25, 2020 Share Posted June 25, 2020 Assuming the current version is the same as the previous with light, it is not connected via the decoder but direct to track with a diode arrangement to rectify DCC to it. Therefore always on. Would be simple enough to modify to run from a switchable function output, but not wired that way out of the box. And it's a LED light. Link to comment Share on other sites More sharing options...
Sir TophamHatt Posted June 26, 2020 Author Share Posted June 26, 2020 Assuming the current version is the same as the previous with light, it is not connected via the decoder but direct to track with a diode arrangement to rectify DCC to it. Therefore always on. Would be simple enough to modify to run from a switchable function output, but not wired that way out of the box.Yeah, it's the current version.Is there a guide for this?Although I may not bother as even the simplistic of tasks mean a broken piece with me. Link to comment Share on other sites More sharing options...
