PDW Posted July 12, 2020 Share Posted July 12, 2020 Hello, using Railmaster Pro latest version, Microsoft Surface, Windows 10 Pro and Elink.When I run my Heljan Class 25 (D5320) - I have excellent control and on the screen (larger control window) the horizontal bar indicated the current speed and at the top of the control fader I get an indication of final speed at that setting.If I now control my Bachmann Class 25 nothing happens until the control fader is half way up it's scale - then the speed indicated on the horizontal scale is 1 mph and the same on the top of the control fader - 1mph.As I increase the throttle the 2 indicators remain at 1 mph - even though the unit is clearly accelerating. I have been playing with the Bachmann CVS and am struggling to get a linear control of the speed over the range of the throttle fader.So 2 questions on the Bachmann -1) is there a way to get accurate speed indications on both horizontal and at the the top of the throttle control?2) Any advice re CV settings to give better (more linear) control of soeed over the travel of the throttle fader?Below I show the CV settings:CV Settings for loco: Bo-Bo Class 25 BR blue (ID: 0053) - DAPOLCV No. CV Name Value Result String1 Primary address 053 99 20 1 53 12 Start voltage 001 99 20 2 1 1163 Acceleration rate 022 99 20 3 22 984 Deceleration rate 009 99 20 4 9 1225 Vhigh 026 99 20 5 26 1046 Vmid 017 99 20 6 17 967 Decoder chip version 059 Loksound decoder8 Manufacturer ID 151 Electronic Solutions Ulm13 Analogue mode 000 99 20 13 0 12217 Extended address 192 99 20 17 192 22818 Extended address 100 99 20 18 100 6729 Decoder config 002 99 20 29 2 4249 Extended config 019 99 20 49 19 8550 Analogue mode 003 99 20 50 3 7051 Brake mode 008 99 20 51 8 7663 Sound volume 010 99 20 63 10 0CV Settings for loco: Bo-Bo Class 25 BR blue (ID: 0025) - BachmannCV No. CV Name Value Result String1 Primary address 025 99 20 1 25 1112 Start voltage 003 99 20 2 3 1183 Acceleration rate 008 99 20 3 8 624 Deceleration rate 006 99 20 4 6 1175 Vhigh 060 99 20 5 60 786 Vmid 020 99 20 6 20 1017 Decoder chip version 059 Loksound decoder8 Manufacturer ID 151 Electronic Solutions Ulm13 Analogue mode 000 99 20 13 0 12217 Extended address 192 99 20 17 192 16618 Extended address 100 99 20 18 100 129 Decoder config 002 99 20 29 2 10449 Extended config 019 99 20 49 19 8550 Analogue mode 002 99 20 50 2 7151 Brake mode 020 99 20 51 20 8063 Sound volume 025 99 20 63 25 81Appreciate any assitance.Phil Link to comment Share on other sites More sharing options...
Chrissaf Posted July 12, 2020 Share Posted July 12, 2020 Ever since the release of RailMaster version 1.72 this issue is raised every week or so. It seems to be a BUG in this particular release..So first thing first, if you haven't done so already. Update RM to the latest version 1.73.On the morning of Friday 3rd July - RM version 1.73 was released..If your version of RM is still at version 1.72. Then I suggest that you manually upgrade RailMaster to this latest 1.73 version release as the 1.73 contains 'BUG' fixes .... what ones is not documented, but it may still fix your issue..The 1.73 update is not an auto-update. It has to be done manually. Download the installer file from the link at the top of the RailMaster forum. Ignore the fact that the link still says it is version 1.72 that text has not been updated yet. The installer that downloads is indeed version 1.73.Do not uninstall your existing version, just make sure that it isn't running..Right click the downloaded installer and choose 'Run as administrator' and just install it directly over the top of the existing version..THEN AFTER INSTALLING 1.73 do the following:.The only known fix so far for the 1 MPH issue has been to completely delete the affected loco from the RailMaster loco roster then add it again from scratch**. This may need to be done more than once for the speed issue to be corrected..Note** As the Bachmann is not a Hornby loco, then I advise that you do not try to add your loco using the Hornby database. I advise that you add the loco manually. This previous tutorial of mine gives guidance on adding a loco manually. Ignore the references to 'sound' in the tutorial if you do not have the Loksound decoder fitted that is mentioned in your CV list..Manually adding a Loco to the RM Database.https://www.hornby.com/uk-en/forum/r3459tts-decoder-not-recognized-23469/.For additional information: Full description of the ‘Locomotive Settings’ screen in detail.https://www.hornby.com/uk-en/forum/changing-cruise-and-shunt-speeds/?p=1.If the combination of upgrading RM to 1.73 AND deleting and re-adding the loco again cures your issue, then please feedback that information in this thread for the benefit of others..This is the last most recent thread discussing the same 1 MPH issue as yours. It has a positive 'issue fixed' outcome --- reported as fixed only 2 days ago..https://www.hornby.com/uk-en/forum/decoder-rme-link-setup-for-class-56-r2750/?p=1.TIP: As a relatively new poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
PDW Posted July 13, 2020 Author Share Posted July 13, 2020 Many thanks for the speedy response Chris; will make a start tomorrow Link to comment Share on other sites More sharing options...
PDW Posted July 13, 2020 Author Share Posted July 13, 2020 Actually - not so simple since MSoft are not happy:/media/tinymce_upload/2815f712cadfdec50c10bf9033a2493a.JPGHave reported it as 'probably safe' option with MSoft and it seems to run happily! Link to comment Share on other sites More sharing options...
Chrissaf Posted July 13, 2020 Share Posted July 13, 2020 I get this as well (or something similar) as I know others do too. Particularly with the very latest Windows 10 2004 Feature Update where MSoft security has been enhanced. It arises because RailMaster was originally written for XP using the now obsolete Visual basic 6 from MSoft..It is a 'false positive' and in this case completely safe to override and continue with the installation. Link to comment Share on other sites More sharing options...
PDW Posted July 15, 2020 Author Share Posted July 15, 2020 Well sadly - have followed the advice above - updated and deleted - to be sure I actually installed 24 245 three times and 25 245 (another class 25 from Bachmann) twice. They both still only show 1 mph in both horizontal and vertical indoicators.To be clear they do run.As an aside I tried to add the picture via the auto scale option each time - but ended up with nothing - I guess using a Hornby Class 25 picture and name probably won't matter as all the motor and funntion CVs can still be idividually set.Anyway - any other suggestions re the speed indicator will be appreciated.Thanks Phil Link to comment Share on other sites More sharing options...
PDW Posted July 18, 2020 Author Share Posted July 18, 2020 Does not look like there is a solution to the speed indication (Deleted Class 25 and re installed for 5th time with no improvement).As I explained above - there seems to be no real speed control with the throttle fader - paticularly noticeable in shunt mode where the throttle has to be raised half way before anything happens.Strangley it immeadiately accelerates to maximumshunt speed - it's like a switch rather than a throttle. Moving the throttle fader to maximum from the onset of motion at the half way point has no effect on the speed at all.The acceleration from rest is too fast in shunt - even though it is smooth in 'non' shunt mode.In non shunt mode - same deal - nothing till half way up throttle and the flat out with no control.Be grateful for any advice......Latest CVs (4th try) below:CV Settings for loco: Bo-Bo Class 24 BR blue (ID: 0024)CV No. CV Name Value Result String1 Primary address 024 99 20 1 24 1102 Start voltage 003 99 20 2 3 523 Acceleration rate 012 99 20 3 12 584 Deceleration rate 006 99 20 4 6 555 Vhigh 040 99 20 5 40 246 Vmid 020 99 20 6 20 397 Decoder chip version 059 Loksound decoder8 Manufacturer ID 151 Electronic Solutions Ulm13 Analogue mode 000 99 20 13 0 12217 Extended address 192 99 20 17 192 16618 Extended address 100 99 20 18 100 129 Decoder config 002 99 20 29 2 10449 Extended config 019 99 20 49 19 8550 Analogue mode 002 99 20 50 2 7151 Brake mode 008 99 20 51 8 1463 Sound volume 030 99 20 63 30 86 Link to comment Share on other sites More sharing options...
96RAF Posted July 18, 2020 Share Posted July 18, 2020 I suggest reporting it in to HRMS pasting in a link to this forum page discussion for their reference rather than having to retell the whole story again with all those lists of numbers.Use the inbuilt query reporting facility. Link to comment Share on other sites More sharing options...
PDW Posted July 19, 2020 Author Share Posted July 19, 2020 Have done that thanks; I will report back in the event I get a resolution. Link to comment Share on other sites More sharing options...
