Malmaniac Posted July 26, 2020 Share Posted July 26, 2020 Being new to model railways I'm looking for some advic.I made a few changes to my grandson's layout yesterday to increase the number of circuits and have three trains running.we have the standard track at oval with extension packs a-f.when I linked two of the sidings and added an inner loop the fault occurre, with the e link flashing.i have disconnected parts of the track and isolated it down to one section which is a standard left hand point.when inserted in the layout to form a siding in shorts the system.if I remove the electro power clips the short stops but if I switch the points it Short's again.my question is have I a faulty piece of track or am I doing something wrong?many thanks for any assistance you may offer. Link to comment Share on other sites More sharing options...
96RAF Posted July 26, 2020 Share Posted July 26, 2020 The point is faulty. You can prove it by swapping the point to another place on the layout or tracing it with the point out of the layout with a multimeter.The fact that the fault is there when you fit the clips or if you select the point direction to siding without the clips proves the diagnosis. Link to comment Share on other sites More sharing options...
Malmaniac Posted July 26, 2020 Author Share Posted July 26, 2020 Thank you for your advice, it's the only left hand point I have so I'll order a new one. Link to comment Share on other sites More sharing options...
Chrissaf Posted July 26, 2020 Share Posted July 26, 2020 This fault on Hornby points seems to be quite common and gets posted a lot. This previous thread details the fault..https://www.hornby.com/uk-en/forum/loop-siding-short-circuit-problem/?p=1/#post-231478 Link to comment Share on other sites More sharing options...
