Chrissaf Posted August 14, 2020 Share Posted August 14, 2020 There should be two black wires on your TTS decoder if it is the same as a merchant navy one. One is the feed to the loudspeaker, one is the track pickup. If you look halfway along the decoder there should a red and black wire connected, these are the speaker wires. The black track pickup comes from the edge of the board. This is one wire you must not get wrong if it is the track pickup, it has the unique ability of blowing up the decoder if connected wrong. Unless you are happy soldering wires it is a return job. Link to comment Share on other sites More sharing options...
JsionyRN Posted August 14, 2020 Share Posted August 14, 2020 Colin B Thank you very much for taking the time to reply looks like it is a return as my dsoldering skills are not good to say the very least Regards Roger RN Link to comment Share on other sites More sharing options...
96RAF Posted August 14, 2020 Share Posted August 14, 2020 Just a picture to illustrate Colins info. The speaker wires are the black and red coming off the right side of the decoder. The pickup and other wires are in that mess at this end. https://images.app.goo.gl/SDZwSBjKc8VrJJUq6 Live linking is still broken so you will have to copy and paste the link text into your browser. Link to comment Share on other sites More sharing options...
Chrissaf Posted August 14, 2020 Share Posted August 14, 2020 Good afternoonI have just purchased a hornby TTs R7146 sound decoder. Unfortunately I cannot seem to get the decoder to work and have noticed that there is a black wire that is loose and not connected.Please could I have some advice as to wether or nor this wire needs to be connected. The loco runs fine with another non sound decoder when fitted.All replies graetfully recievedRgegards Roger RN Link to comment Share on other sites More sharing options...
