AndyMac1707817969 Posted August 17, 2020 Share Posted August 17, 2020 Can someone enlighten me as to the problem with the lights not working on the Hornby R4869 Network Rail DVT 82124 produced by Kernow Exclusive? Apparently there was a problem with the pickups that caused the lights not to work. I have been told it was a manufacturing fault, but there is some modification you can do to fix it. Link to comment Share on other sites More sharing options...
Chrissaf Posted August 17, 2020 Share Posted August 17, 2020 I would have thought that Kernow Models should be your first port of call with this question, particularly if it is known manufacturing fault as you believe. One would expect Kernow to be 'chapter and verse' knowledgeable on this issue if it is manufacturing design issue. Link to comment Share on other sites More sharing options...
