Chrissaf Posted August 19, 2020 Share Posted August 19, 2020 Yes, it can be removed, the "suppression" circuitry is included in the decoder itself. Link to comment Share on other sites More sharing options...
Potrail2378 Posted August 19, 2020 Share Posted August 19, 2020 Does it just get cut out, or is there any soldering needed? Link to comment Share on other sites More sharing options...
96RAF Posted August 19, 2020 Share Posted August 19, 2020 Some can just be cut out but some are better desoldered.Check for any hidden under the motor, as some manifacturers can be sneaky. Link to comment Share on other sites More sharing options...
Chrissaf Posted August 19, 2020 Share Posted August 19, 2020 Hi, and thanks for all your recent help. I have a freight set and two loco's, R1126 with a Jinty and a class 08. I have recently converted the class 08 four pin decoder to a four pin, five wired decoder with your help. What's with the capacitor? Is it necessary? Can I cut it out? I thought the caps were only fitted on DC models. Thanks in advance. Link to comment Share on other sites More sharing options...
Potrail2378 Posted August 19, 2020 Share Posted August 19, 2020 Sorry, what I meant to say was - does it just get cut out, or is there any bridging to do when removing the capacitor? Link to comment Share on other sites More sharing options...
Chrissaf Posted August 20, 2020 Share Posted August 20, 2020 Just removal, no replacement bridging required for a capacitor as the capacitor goes across the motor terminals in parallel with the motor wires. A capacitor is an 'open circuit' to DC, so if you replaced a suppression capacitor with a metallic wire link you would be creating a 'short circuit' across the motor and thus the motor output of the decoder..However, sometimes the suppression takes the form of inductors in series with the motor wire connections [sometimes as well as parallel capacitors], in which case once the inductor is removed the resultant dangling wire needs to be reattached to the motor [usually by soldering] to replace the electrical current path previously provided by the inductor. Link to comment Share on other sites More sharing options...
