Metijg Posted August 26, 2020 Share Posted August 26, 2020 I'm looking for a child friendly, cheap, DCC controller so the Select seems perfect as it doesn't look more intimidating that an analogue controller and is only a bit more expensive. However, the compatability part worries me. Can anyone tell me if this is really a problem? I was thinking of using i it for small engines so probably looking at ESU or Zimo decoders. Thanks in advance! Link to comment Share on other sites More sharing options...
Chrissaf Posted August 26, 2020 Share Posted August 26, 2020 If you are buying a brand new Select, then ESU and Zimo should be fine. If you are buying secondhand then you might be buying a Select with a very early firmware..If necessary, check with the seller what firmware revision the Select has..The current installed firmware is displayed as the very first number to briefly appear on the Select screen as it is being powered up. Expect to see a number between 10 and 20. At the time of writing, the latest version is 1.6 [16] or 2.0 [20] - both the same. These latest versions completely transform the user experience of the Select controller and add the ability to write (not read) all CVs up to CV255. As well as access to the full F0 - F28 range of functions..The upgrade charge is typically £15 plus VAT [£18] plus your sending postage costs. You need to get a 'returns number' from Hornby Customer Services - see 'Contact Us' link at the very bottom of the page..If you do arrange to get your Select firmware upgraded, then you will need both the Select version 1.5 full manual and the version 1.6 addendum manual. As the operation of your Select (how to use it) will be completely different in certain areas of operation compared to your current firmware version..You can download these two manual PDFs from here:https://www.hornby.com/uk-en/downloads/view/index/cat/12/.If nothing appears to happen, check your nominated browser download folder for the files as they can download silently in the background. Link to comment Share on other sites More sharing options...
Metijg Posted August 26, 2020 Author Share Posted August 26, 2020 Thanks!I was looking to buy one from Hattons where there are less than 100 quid (just!) and i presume it's the latest firmware. Your comments give me the confidence to go ahead!Thanks again Link to comment Share on other sites More sharing options...
westernwill Posted August 26, 2020 Share Posted August 26, 2020 I would ring and make sure about the firmware level and be quick. Thay only have 1 in stock. Link to comment Share on other sites More sharing options...
