JOSSY65 Posted September 2, 2020 Share Posted September 2, 2020 can anyone help me, can you put a hornby class 66 tts sound decoder into a class 67 loco Link to comment Share on other sites More sharing options...
Chrissaf Posted September 2, 2020 Share Posted September 2, 2020 A decoder is a decoder ... it really doesn't matter what loco it is put into. So subject to the normal caveats relating to physical space, and electrical current consumption suitability etc. Then there is no reason why a TTS 66 cannot go into a 67. Your question should really be "Are the sounds the 66 TTS decoder make suitable for a 67 loco?". To which the answer would be "It depends" ... it depends how much of a 'rivet counting purest' you are with regard to sounds made accuracy. Link to comment Share on other sites More sharing options...
JOSSY65 Posted September 2, 2020 Author Share Posted September 2, 2020 Thank you chrissaf i'm not too fussy about the sound as long as it sounds near enough Link to comment Share on other sites More sharing options...
96RAF Posted September 2, 2020 Share Posted September 2, 2020 Listen to each class on u-tube to see if there are any characteristic differences, such as basic engine note at idle and upon acceleration, horns, various fans and valves, etc. Try to find a video of the startup sequence. Link to comment Share on other sites More sharing options...
ellocoloco Posted September 2, 2020 Share Posted September 2, 2020 Both the 66 and 67 have the same version on the EMD 710 series engine and the same traction motors so they should be very similar. The exhaust set up does look slightly different though..... As the guys above say, there may also be differences to the 'ancillary noises'. Link to comment Share on other sites More sharing options...
JOSSY65 Posted September 3, 2020 Author Share Posted September 3, 2020 Thank you for all your help guys much appreciated Link to comment Share on other sites More sharing options...
