2bad Posted September 3, 2020 Share Posted September 3, 2020 hi I have a hornby select I've successfully programed six locomotives upto now. I've tried to program another one at address seven and it just doesn't accept it .tried number 8.9.10 and so on can anyone tell me what the problem could be . Link to comment Share on other sites More sharing options...
Rog RJ Posted September 3, 2020 Share Posted September 3, 2020 You could try resetting the Select, this has been known to cure all sorts of odd problems. Link to comment Share on other sites More sharing options...
mjb1961 Posted September 3, 2020 Share Posted September 3, 2020 Hi,it could be the decoder itself,to rule out the select try re programming one of the other trains ,also if not to much trouble swap round decoders ,that way you should be able to narrow down to the problem. Link to comment Share on other sites More sharing options...
96RAF Posted September 3, 2020 Share Posted September 3, 2020 If your Select is at v1.6 or higher you could try writing that address directly into CV1.If it is below this version then you are limited to the standard addressing method. Inability to address a decoder could mean the installation is bad. Link to comment Share on other sites More sharing options...
2bad Posted September 3, 2020 Author Share Posted September 3, 2020 Hi,it could be the decoder itself,to rule out the select try re programming one of the other trains ,also if not to much trouble swap round decoders ,that way you should be able to narrow down to the problem.Hi thanks for your advise but I have tried that and the same thing happened I tried it on anther select and had no problem programming it Link to comment Share on other sites More sharing options...
Chrissaf Posted September 3, 2020 Share Posted September 3, 2020 In that case, try resetting the Select as Rog(RJ) advised ... further above in his reply..TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum..https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
