Airband1 Posted November 15, 2011 Share Posted November 15, 2011 hy im new to this site and i have just wired up my turntable as instructed on the dcc sheet i am also having problems with the loco having no feed whilst on the turntable, anyone have any ideas to overcome this issue? Link to comment Share on other sites More sharing options...
Blackbird Posted November 16, 2011 Share Posted November 16, 2011 Hi Airband1, The power to the T/T bridge is supplied from the designated input track, this must be 'live', ie connected to the DCC system. If this is correct, check the continuity of the track pickups at this point, then the continuity of the wipers under the bridge. You could also read my previous listing (above)! Link to comment Share on other sites More sharing options...
crg Posted December 22, 2011 Share Posted December 22, 2011 Hi - sorry to interrupt, but I am a novice. I have taken delivery of a R070 turntable which I wish to wire up to my DCC Elite controller. I have read the previous threads but remain confused. In simple terms where do I connect the brown and black wires from the turntable? Is there a diagram? I do not understand the terms 'bus' and 'dropper' wires so please keep it simple for my simple mind. Seasonal greetings and very many thanks in advance. Link to comment Share on other sites More sharing options...
poliss Posted December 22, 2011 Share Posted December 22, 2011 Will you be using a locomotive decoder? If so, then the brown and black wires from the turntable should be connected to the orange and grey wires from the decoder as shown on this Hornby instruction page. https://www.hornby.com/hornby-dcc/decoder-installation-guides/turntable-conversion/Use heat shrink tube on the joints between the wires, not insulation tape as the instructions say.You put the heat shrink tube on the wires first before joining the wires together. Once the joints are made, you slide the heatshrink tube over the joints and shrink it with the back of asoldering iron. Link to comment Share on other sites More sharing options...
crg Posted December 22, 2011 Share Posted December 22, 2011 poliss said:Will you be using a locomotive decoder? If so, then the brown and black wires from the turntable should be connected to the orange and grey wires from the decoder as shown on this Hornby instruction page. https://www.hornby.com/hornby-dcc/decoder-installation-guides/turntable-conversion/Use heat shrink tube on the joints between the wires, not insulation tape as the instructions say.You put the heat shrink tube on the wires first before joining the wires together. Once the joints are made, you slide the heatshrink tube over the joints and shrink it with the back of asoldering iron. Link to comment Share on other sites More sharing options...
crg Posted December 22, 2011 Share Posted December 22, 2011 Thank you for that. I already have an accessory decoder. Is there a way of using it to operate the turntable? Many thanks. Link to comment Share on other sites More sharing options...
poliss Posted December 22, 2011 Share Posted December 22, 2011 You will need an R8247 accessory decoder to operate a turntable. It can't be done with the R8216.I think it would be easier to use a locomotive decoder.FinnerZ said in a post 166 days ago "I've tested the output of the accessory decoder and if you do decide to go down this route, you will only be able to make it run in one direction, and at one speed. Connect one wire to the common terminal and the other to either the + or - terminal. When you call up the turntable, one press will stop it and the other will make it move. The same should work for the lighthouse. I haven't tried running a turntable in this way but it would make sense. Good luck." Link to comment Share on other sites More sharing options...
