Mick1968 Posted May 10, 2012 Share Posted May 10, 2012 Hi I have got a pendolino, it was working fine, the motor end was ok but i noticed the back end lights were flickering i re-soldered the wires put it back together put it on the track sa bit of black smoke appeared now the motor and dummy end dont work at all Link to comment Share on other sites More sharing options...
Mick1968 Posted May 10, 2012 Author Share Posted May 10, 2012 so stripped it down again the motor still runs ok please helpthank youmicklloyd11@hotmail.com Link to comment Share on other sites More sharing options...
brando Posted May 12, 2012 Share Posted May 12, 2012 sounds like you have a short circuit somewhere. Link to comment Share on other sites More sharing options...
96RAF Posted May 12, 2012 Share Posted May 12, 2012 MickCheck where you were soldering those wires as it is likely you may have bridged across pcb tracks or similar and caused a short like brando said.Rob Link to comment Share on other sites More sharing options...
2e0dtoeric Posted May 12, 2012 Share Posted May 12, 2012 And if you got black smoke, something has failed, permanently. It sounds like a professional repair job. Link to comment Share on other sites More sharing options...
Mick1968 Posted May 21, 2012 Author Share Posted May 21, 2012 Mick1968 said:so stripped it down again the motor still runs ok please helpthank youmicklloyd11@hotmail.comthanks again Link to comment Share on other sites More sharing options...
Mick1968 Posted July 1, 2014 Author Share Posted July 1, 2014 not sure what causes that, but i had the problem with my pendolino a couple of years ago, i took mine to the local model shop the sorted it for me lights are not working on mine now Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 1, 2014 Share Posted July 1, 2014 To start on a light note, then get more serious, all electronic components and circuits are manufactured with a sealed section containing smoke. If a component fails, its last act is to rupture this section and release the smoke, confirming to you it has in fact failed and you need to get a new one. Now for the serious, why did it fail? There are 2 common reasons. The first is to cause it produce more than its rated current by connecting it to a motor that is drawing more either running or when stalled. In this case, it is usually one or more of the 4 larger black diodes near where the wires connect to the decoder that fail. They will be looking very charred if this happens. You can only have caused such a fault via a short circuit by accidentally soldering between any of the output wires of the decoder, starting with motor output orange and grey, but possibly one or more of the function outputs like yellow and white used for the lights. The other sure fire way is to connect either of input red or black to output orange or grey. in either case, you will need to find the short, remove it and replace the decoder. Link to comment Share on other sites More sharing options...
Michael_A Posted July 2, 2014 Share Posted July 2, 2014 Well I have worked in electronics for 40 years and never heard of components having a sealed section containing smoke before. I always though the smoke was emitted due to overheating / burning of the materials used in the manufacture of the individual components? Link to comment Share on other sites More sharing options...
Augustus Caesar Posted July 2, 2014 Share Posted July 2, 2014 It's the leftovers of the good old Woodbines left during manufacture that is placed in the component so the smoke lasts long enough for the user to see it and if you put your nose close to the loco you'll smell that distinctive ciggy smell you get when someone stands near you who smokes 20 or 30 a day and doesn't notice that aroma they carry... :-) Or could it be that Fishy is pulling a fast one here? I've never heard that one before and if the Aussies use smoke in their chips it's great that we use salt and vinegar! :-) Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 2, 2014 Share Posted July 2, 2014 Sorry Michael, just my little joke. I did say I was starting on a light note. And AC, I prefer my chips as they come, no salt, vinegar or smoke. Link to comment Share on other sites More sharing options...
96RAF Posted July 3, 2014 Share Posted July 3, 2014 It obviously costs more to have the smoke capsules fitted as all the expensive electronic components I have killed off all had smoke fitted. The cheap ones have never smoked. Link to comment Share on other sites More sharing options...
Graskie Posted July 3, 2014 Share Posted July 3, 2014 I suppose the cheap non-smokers must be healthier then. Link to comment Share on other sites More sharing options...
Augustus Caesar Posted July 5, 2014 Share Posted July 5, 2014 The cheap non smokers have patches fitted... Link to comment Share on other sites More sharing options...
Michael_A Posted July 8, 2014 Share Posted July 8, 2014 Thanks goodness we have a sense of humour! You got me on that one! Link to comment Share on other sites More sharing options...
