modelman1963 Posted May 12, 2012 Share Posted May 12, 2012 hi again all.i have the select controler, is it best to only use hornby trains or does it work well with all makes of train? Link to comment Share on other sites More sharing options...
poliss Posted May 12, 2012 Share Posted May 12, 2012 The Select will work with Honby decoders. The Select should work with most other makes of decoders. Link to comment Share on other sites More sharing options...
robbi37 Posted May 14, 2012 Share Posted May 14, 2012 Hi modelman1963. I would not rely on it working with all decoders of other manufacturers as the select is not NRMA compliant. it should work with all Hornby decoders but you will be limited to what CV,s you can adjust and what functions you can access. I found my select would work with a lot of the other manufacturers decoders,but I found a Bac*&^n 21 pin decoder would not work with my select. So I updated to a Elite and it would not work with that either so I had to fit a Hornby Sappire 21pin decoder. It now works fine. I think until you try them you wont know for sure. Link to comment Share on other sites More sharing options...
tsclass87 Posted May 14, 2012 Share Posted May 14, 2012 Post a new reply... Link to comment Share on other sites More sharing options...
tsclass87 Posted May 14, 2012 Share Posted May 14, 2012 pleaae see answer given in lights concernong elite and versions used to control bachxxx 21 pin decoders. Link to comment Share on other sites More sharing options...
