The-Heff Posted December 8, 2020 Share Posted December 8, 2020 HiCan you add two TTS sound chips to a Power Loco and Dummy Loco that are DCC ready, i was told by someone that you could install sound chips in both Locos for duel sound...is this correct or just a waste of time.. thank you in advance for you replys... Link to comment Share on other sites More sharing options...
96RAF Posted December 8, 2020 Share Posted December 8, 2020 Yes you can. Hornby even sell a TTS twin pack for their HST powered and dummy Class 43 locos. You can give them the same address then both decoders will play the same thing at the same time ...or you can give them different addreses and control each separately ...or you can run them in a consist (double header) and the motors will run together but the functions will be able to be operated separately. What you have to watch is if you had a dummy steam loco (unlikely I know, but some folk run a dead loco in a double header just for show) is that TTS needs the BEMF of a motor to make the chuff/coast work properly. This is not so for diesels which can work TTs without a motor. Link to comment Share on other sites More sharing options...
