Poppadoom Posted December 11, 2020 Share Posted December 11, 2020 Hi all, I'm looking to fit a dcc decoder to my son's old locos after upgrading his controller. one model in particular is worrying me slightly, as there doesn't look to be much room inside, t's the L6360 pacer set. There are two powered units in this set, so I also wondered whether I can run both motors from one dcc chip, or would the current draw be too much to do this? Does anyone have any advice/experience of doing this to this model? Link to comment Share on other sites More sharing options...
96RAF Posted December 11, 2020 Share Posted December 11, 2020 Although not Lima these are likely to be very similar inside. See herehttps://www.hornby.com/uk-en/hornby-dcc/decoder-installation-guides/r2611-class-142-railbus-pacer/ and herehttp://s374444733.websitehome.co.uk/class-142sound/index.htm It is unlikely that a single decoder would have the oomph to run both motors, so two decoders is the better method. Link to comment Share on other sites More sharing options...
Chrissaf Posted December 11, 2020 Share Posted December 11, 2020 Subject to motors used, the current drawn by just one of the motors might possibly exceed the current available from a Hornby decoder net alone two motors. Personally, I would perform a 'stall test' on DC first to see the maximum current draw, then select a suitable decoder [possibly a non Hornby one] that meets the measured current draw requirement. As Rob says, one decoder per motor. Also subject to the decoder, the decoder might use the motor 'Back EMF' as part of its control methodology. Having two motors in parallel is likely to confuse a decoder if it sees the 'Back EMFs' of two motors conflicting with each other. TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button. See also – further TIPs on how to get the best user experience from this forum. TIPs include 'How to post images' and 'How to make links clickable'.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/ Link to comment Share on other sites More sharing options...
