bryan_passey Posted December 12, 2020 Share Posted December 12, 2020 Can anyone out there, or Hornby, tell how to visially distinguish between power connectors R602 and R8242 . The first item has a capacitor in it the other does not.For DCC R 8242 is to be used ( without capacitor ) I need to know the difference, or can i use iether on DCC ? Link to comment Share on other sites More sharing options...
Chrissaf Posted December 12, 2020 Share Posted December 12, 2020 You can use either on DC Analogue, but you cannot use either on DCC Digital. Outwardly, the R602 and the R8242 look identical, they may even use the exact same factory production mould. The R8242 usually has a small paper label stuck on the underside saying R8242, but these can fall off. The only way to categorically tell the difference is to flip open the cover and look for the internal capacitor. The R602 has one, the R8242 does not. The R602 can be converted to become a R8242 by opening the flip cover and removing the capacitor. /media/tinymce_upload/4aed41bfaa6337e8b4e0046bfc15ecff.jpg Note that the capacitor also needs to be removed from the R8206 Power Track for use on a DCC layout, or use the R8241 which already has the capacitor removed. The R8206 is distinguishable by its pinky buff press buttons. The R8241 has dark grey or sometimes green press buttons. TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button. Particularly as my reply includes an image, using the 'Blue Button' may result in your reply being held back for image approval, even though it is an existing image. See also – further TIPs on how to get the best user experience from this forum. TIPs include 'How to post images' and 'How to make links clickable'.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/ Link to comment Share on other sites More sharing options...
96RAF Posted December 12, 2020 Share Posted December 12, 2020 Strange that the one without the capacitor is more expensive than the one with. Less is £-more obviously. Link to comment Share on other sites More sharing options...
