TTS - Class 47 R8103
Guest Chrissaf
The Green wire is switched via F25. I wonder if it's possible to incorporate a motion sensor in circuit with whatever device you wish to control that would be on when sensing forward movement then off when stationary or possibly a reed switch......care would be needed to avoid exceeding the function load limit of 100mA............HB
Bonjour, pour le décodeur de son
est-il possible de piloter le fils vert en fonction de la direction de la locomotive
ex: avant ok , arrière stop
merci
Hello, for the TTS sound decoder - class 47 R8103
is it possible to drive the green wire according to the direction of the locomotive ex: forward ok, back stop
thank you
Frédéric Labbé
