Jes TGU Posted January 9, 2021 Share Posted January 9, 2021 I have a TTS sound locomotive, (R3902) and railmaster is consistently failing to read the CVs of the train. The train runs fine on the main track and I know the connection between the prog track and the E-link is fine. The track for the prog track is brand new, and so is the locomotive so they are both clean. I don't understand why it will not read the CVs. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 9, 2021 Share Posted January 9, 2021 Can you read a completely different loco. If the answer is no or not consistently and reliably, then there is still something wrong with the connectivity between controller and loco decoder. Again if the answer is no, then there is also the possibility that the eLink 'PROG A&B' output is faulty. TIP: As a low post count poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button. See also – further TIPs on how to get the best user experience from this forum. TIPs include 'How to post images' and 'How to make links clickable'.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/ Link to comment Share on other sites More sharing options...
96RAF Posted January 9, 2021 Share Posted January 9, 2021 Does RM recognise the decoder as TTS or is it seeing it as an R8249, in which case it will not load the correct TTS CV set to read and hence skips them. You can double click CV 7 and pick a TTS decoder from the drop down list provided which should help. Link to comment Share on other sites More sharing options...
Jes TGU Posted January 11, 2021 Author Share Posted January 11, 2021 The locomotive runs fine on the normal track and sounds are good, I have tried programming a different loco and that didn't work either. I switched the output to main track to check the connection and it ran fine. Could it be a problem with the programming track input? Also, for clarification, I added this locomotive manually. The other loco i tried was not added manually and didn't work. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 11, 2021 Share Posted January 11, 2021 OK you can't read a CV, but can you write one? For example you say you have more than one loco. Have you changed their addresses from the default 03 address to something different, or are you running them all on the default 03 address? If you have changed their addresses, then that would seem in to indicate that the eLink programming output is OK and that it might be your CV reading methodology that is wrong. Something else that can have a bearing on CV reading / writing. How are you physically connecting your eLink 'PROG A&B' output to your new 'Programming' track piece. If it is a Hornby Power Track or a Hornby Track Power Clip. Then these need to be DCC compatible. It won't work if you use the standard Analogue power track products which are R8206 Power Track with Buff/Pink press buttons or the R602 Power Clip. You need to use the DCC variants R8241 or R8242. The above also applies to the the connections that you make to your main layout track. That also needs to use DCC compatible connections. Link to comment Share on other sites More sharing options...
