Slowhand Posted January 11, 2021 Share Posted January 11, 2021 Hi All an odd one for advice if possiblelast night random trains on my set up started movingprobably 8-10 trains on the track and sidings but only two in operationsuddently trains would start moving, TTS programmes that I would normally use would start (lights, engine and one of the horns) if I quickly typed in the address into the Elite then nothing was showing on the selected trainthe Elite is unplugged every night so seems unlikey it is remembering a previous instruction will do a full reset this eveningall thoughts welcomethanksEric Link to comment Share on other sites More sharing options...
96RAF Posted January 11, 2021 Share Posted January 11, 2021 Likely to be a poor track bus, if you even have one. Do you have power clips or power track connections to the Elite, if so habe you checked they do not have capacitors fitted as they will corrupt the DCC signal.I had a lashed up loop to loop power distribution on a triple loop test track and I saw uncommanded movement and ‘son et lumiere‘ TTS events.My bus wiring was totally inadequate for the job and I blamed it all on that.If you have a track bus system then you may need to consider bus terminators, easily made for pennies or bought for pounds. Even on my new layout with a proper bus system and terminators I have the odd loco that sounds a horn as it traverses a single point, not,every time but now and then, so again corrupt DCC signal suspected. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 11, 2021 Share Posted January 11, 2021 Rob wrote: "Do you have power clips or power track connections to the Elite, if so have you checked they do not have capacitors fitted as they will corrupt the DCC signal." This is what he means: /media/tinymce_upload/b4bc5cbd304ea302a225a960d60cdc7e.jpg These capacitors can potentially be a root cause of the odd DCC behaviour that you are observing. Link to comment Share on other sites More sharing options...
Slowhand Posted January 11, 2021 Author Share Posted January 11, 2021 Thanks bothive a couple of the Hornby R8241 digital power track connectors - would they do it? I'm presuming that's what's in your right hand picture Chris? Link to comment Share on other sites More sharing options...
Chrissaf Posted January 11, 2021 Share Posted January 11, 2021 The R8241 is the correct power track for DCC and should not contain the problematic capacitors in them. The picture shows a R8206 Analogue power track. You can tell the difference because the R8206 has Buff/Pink Press Buttons and the buttons on the R8241 are usually Dark Grey or sometimes Green. Link to comment Share on other sites More sharing options...
Rog RJ Posted January 11, 2021 Share Posted January 11, 2021 In any case, it's worth having a look inside to make sure there is no capacitor fitted. Having unnecessary parts fitted inside isn't unknown. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 11, 2021 Share Posted January 11, 2021 Rog (RJ) is right to suggest that a check is made anyway, as I have a vague recollection that some very early R8241s left the China factory with the R8206 capacitor still inside them. These were typically found in early Digital Train Sets. Link to comment Share on other sites More sharing options...
Slowhand Posted January 11, 2021 Author Share Posted January 11, 2021 Thanks again - the level of support and help you guys give the community is absolutely brilliant will See what I can find tonight Link to comment Share on other sites More sharing options...
