FIDOLLO Posted January 16, 2021 Share Posted January 16, 2021 hello, I have a TTS Sound Decoder - Class 47 R8103. When the loco starts up, there are tremors and flickering lights. Is there an adjustment to make in the cv and which ones. thank youFrédéric labbé Link to comment Share on other sites More sharing options...
Howbi Posted January 17, 2021 Share Posted January 17, 2021 If the sound is inconsistent and the lights are flickering I would suggest removing the body and checking that the decoder plug is fitted securely in the socket.........HB Link to comment Share on other sites More sharing options...
FIDOLLO Posted January 18, 2021 Author Share Posted January 18, 2021 Si le son est incohérent et que les lumières clignotent, je suggérerais de retirer le corps et de vérifier que la fiche du décodeur est bien fixée dans la prise ......... HBhello, the problem is repeated on the white and yellow wire the green wire is not affected, thank you Link to comment Share on other sites More sharing options...
