beejay Posted March 31, 2021 Share Posted March 31, 2021 Hi folks, i'm seriously considering buying the Mallard with TTS sound (R3395) but after reading the reviews, which were by and large complimentary, somebody mentioned that it wouldn't work with their 'Select' controller, which is what I use. Mine was upgraded by the factory a few years ago and comes up with '15' when first switched on. I'm still a novice at this digital stuff so please, no long winded technical answers if possible !! grinning Thanks. Link to comment Share on other sites More sharing options...
Mac-_- Posted March 31, 2021 Share Posted March 31, 2021 Hmm is it different too any other loco (foreby the shell ;) ), can't see why it wouldn't it run with the select. The Select is a good controller. Link to comment Share on other sites More sharing options...
Chrissaf Posted March 31, 2021 Share Posted March 31, 2021 Short simple yes / no answer.15 means version 1.5 firmware. This firmware is fine for operating Hornby TTS decoders.Long winded technical answer.Version 1.5 firmware adds support for functions F0 to F28 which is what you need to play the TTS sounds.If you were to upgrade to version 1.6 firmware, then you would also add the ability to write [but not read] CVs 1 to 255. This would include writing 8 to CV8 which is a decoder 'reset'. This is something you cannot do with your current version 1.5.Your 'Select' not compatible comment [the misinformed blind leading the blind in this case**], arises from Selects with earlier than 1.5 firmwares having limited support for 'functions'. These early Selects could operate the motor but could not play all the available sounds.Note** no disrespect intended to any visually impaired forum member. Link to comment Share on other sites More sharing options...
Mac-_- Posted March 31, 2021 Share Posted March 31, 2021 Is that note at the bottom of your post a dig at me Chris? Link to comment Share on other sites More sharing options...
Chrissaf Posted March 31, 2021 Share Posted March 31, 2021 No, not at all. It is a dig at the person who told beejay that the Select wasn't compatible with TTS decoders.If you look at my post again I wrote and I quote:"Your 'Select' not compatible comment [the misinformed blind leading the blind in this case**], arises.........."As you can see, it was 'beejay's' comment I was responding to, where 'beejay' wrote and I quote:"somebody mentioned that it wouldn't work with their 'Select' controller......."My comments had nothing at all to do with what you wrote. Link to comment Share on other sites More sharing options...
Mac-_- Posted March 31, 2021 Share Posted March 31, 2021 Sorry Chris, i had a touch of little man syndrome there blush. Link to comment Share on other sites More sharing options...
beejay Posted April 1, 2021 Author Share Posted April 1, 2021 Hi Chris, thank you for your response, that was just the answer I needed, albeit an expensive one as you've just cost me a lot of money !! grinning Thanks again and kind regards,Brian Link to comment Share on other sites More sharing options...
