joseph37 Posted May 29, 2012 Share Posted May 29, 2012 hi.. how do i fit a decoder to a hornby class 37 with a x337 motor Link to comment Share on other sites More sharing options...
koo9 Posted May 30, 2012 Share Posted May 30, 2012 Go here....http://railsintheroof.blogspot.co.uk/2007/10/fitting-dcc-decoder-to-hornby-class-37.html Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 30, 2012 Share Posted May 30, 2012 I think koo9 has it right. Although the Class 37 seems t ocome in many guises, they all seem to have a 3-pole ringfield motor and so installation is as koo9 says, or similar to the Hornby HST, which you can find at https://www.hornby.com/hornby-dcc/decoder-installation-guides/You might also check http://www.hornbyguide.com/item_menu.asp and put Class 37 in model/search and you'll be able to find your particular model and its servie sheet (NO 105 or 210 covers them all I think. Link to comment Share on other sites More sharing options...
poliss Posted May 30, 2012 Share Posted May 30, 2012 It's always useful if you give the R number. Link to comment Share on other sites More sharing options...
Yojic Posted May 30, 2012 Share Posted May 30, 2012 Joseph,If it is the X337 power bogie with an X03/X04 motor then it is not a Ringfield. These are dated back to 1968 Triang Hornby. If it is the X04 motor service sheet http://www.hornbyguide.com/service_sheet_details.asp?sheetid=144 The service sheet for the power bogie http://www.hornbyguide.com/service_sheet_details.asp?sheetid=126 These are more awkward to fit a decoder. If you have given the correct info does the bogie look like this? http://www.ebay.com.au/itm/ws/eBayISAPI.dll?ViewItem&_trksid=p4340.l2557&item=150780309771&nma=true&rt=nc&si=lRky6Mhxi5Q7aYhPHe2eg97wHOc%253D&orig_cvip=true&rt=ncNow not 100% sure on this., both brushes needs to be isolated, to do this the brush spring needs to be insulated (heat 1.5mm shrink tubing will do) both sides. Orange decoder wire soldered to the Right Brush tab.Grey decoder wire soldered to the Left side brush tab.Red decoder wire to the Right side wheel pick up.Black decoder wire to the Left side wheel pick up.The orange/brown capacitor needs to be removed.... Guys please correct if wrong!!!!!!!! as mentioned not 100% sure.You would need a decoder with at least 1.25 amp continuouse and a 2 amp stall. If by chance is your loco a Hornby R751 Class 37 later that 1978Service sheet http://www.hornbyguide.com/service_sheet_details.asp?sheetid=23 If it is this one then it is a 3 pole Ringfield Motor. Easy to convert. Link to comment Share on other sites More sharing options...
joseph37 Posted May 30, 2012 Author Share Posted May 30, 2012 poliss said:It's always useful if you give the R number. Link to comment Share on other sites More sharing options...
joseph37 Posted May 30, 2012 Author Share Posted May 30, 2012 the r number is ..r751 Link to comment Share on other sites More sharing options...
Yojic Posted May 30, 2012 Share Posted May 30, 2012 Joseph,I posted earlier with links but the moderators are withholding at the moment. If it is the Old Bogie with the X04 motor, these have a spring bolted on the top of the bogie and clips the the brushes in place either side pointing downwards(brushes are horizontal). One side is insulated and the other is not. The pick ups either side of the wheels are conected at the top either side as well. Service sheet 69 Is that correct? Link to comment Share on other sites More sharing options...
Yojic Posted May 30, 2012 Share Posted May 30, 2012 whoops mistake the brushes are vertical, the springs travel down the horizontal the clip the brushes in place. Link to comment Share on other sites More sharing options...
joseph37 Posted May 30, 2012 Author Share Posted May 30, 2012 Post a new reply... Link to comment Share on other sites More sharing options...
joseph37 Posted May 30, 2012 Author Share Posted May 30, 2012 the service sheet is number 69 but still does not give anything on fitting a dcc decoder and the motor is a x337 motor Link to comment Share on other sites More sharing options...
joseph37 Posted May 30, 2012 Author Share Posted May 30, 2012 yes yojic sheet 69 is right Link to comment Share on other sites More sharing options...
Yojic Posted May 30, 2012 Share Posted May 30, 2012 joseph37 said:the service sheet is number 69 but still does not give anything on fitting a dcc decoder and the motor is a x337 motorJoseph,Then this is the old x04 motor dating back to 1968. The X337 is the complete power bogie.Steps to hard wire a decoder. I advise to use a decoder with 1amp continuous and 2 amp stall.Chaps please advise if incorrect, not 100% sure on this oneFirst step Know the decoder wires and where they go. Important ones with asterix1 Orange wire Motor Right * 2 Yellow wire Rear Headlight 3 Green Function 14 Black Left Rail * 5 Gray Motor Left *6 White Front Headlight7 Blue Common (V+)8 Red Right Rail *9 Purple function 2Remove the capasitor S52301/ X665 Brush spring. These need to be insulated both sides 2/ solder orange wire to right hand X67 Brush at top3/ Solder grey wire to left hand X67 Brush at top3/ Solder red wire to right hand S3283 collector (make sure the collector is isolated from center at top)4/ Solder black wire to left hand S3283 collector (again make sure it is isolated from center top)Be careful of S3374 top housing contact washer that it does not touch the collectors either side.Hopefully test should be OK.......... Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 31, 2012 Share Posted May 31, 2012 Joseph, I think Yojic has it spot on, everything he says is correct I think. If I can just add/emphasise a couple of points for you:- the only decoder wires you need are the red and black, which go to the collectors one each side, and the orange and grey which go to the brushes, one each side. Cut the rest off and insulate the ends.- cannot use the R8249 standard Hornby decoder as it doesn't have enough power. If you use Hornby, it must be the Sapphire but there are other options around which are cheaper but must be 1 amp/2 amp as Yojic says- you will find the brush spring is only insulated on 1 side and you must insulate both sides and solder the orange wire to the right brush and grey to the left - essential the collectors are electrically isolated as Yojic saysTo do this mod, you will have to know how to use a soldering iron and a multimeter or contunuity tester (to ensure everything is isolated as per instructions). If you aren't familar, take it to a model shop that has a decoder fitting service to do it for you. Link to comment Share on other sites More sharing options...
Yojic Posted May 31, 2012 Share Posted May 31, 2012 Joseph,Photos on other Web thread as cannot attach here. Link to comment Share on other sites More sharing options...
The son of Triangman Posted May 31, 2012 Share Posted May 31, 2012 For those fitting Tri-ang motors I issued on the forum a very useful guide, it is for the x.04 instead of the motor you have but a fair bit will apply to your fitting.You will need to trawl the DCC section for the link. Link to comment Share on other sites More sharing options...
joseph37 Posted June 2, 2012 Author Share Posted June 2, 2012 Yojic said:Joseph,Then this is the old x04 motor dating back to 1968. The X337 is the complete power bogie.Steps to hard wire a decoder. I advise to use a decoder with 1amp continuous and 2 amp stall.Chaps please advise if incorrect, not 100% sure on this oneFirst step Know the decoder wires and where they go. Important ones with asterix1 Orange wire Motor Right * 2 Yellow wire Rear Headlight 3 Green Function 14 Black Left Rail * 5 Gray Motor Left *6 White Front Headlight7 Blue Common (V+)8 Red Right Rail *9 Purple function 2Remove the capasitor S52301/ X665 Brush spring. These need to be insulated both sides 2/ solder orange wire to right hand X67 Brush at top3/ Solder grey wire to left hand X67 Brush at top3/ Solder red wire to right hand S3283 collector (make sure the collector is isolated from center at top)4/ Solder black wire to left hand S3283 collector (again make sure it is isolated from center top)Be careful of S3374 top housing contact washer that it does not touch the collectors either side.Hopefully test should be OK.......... Link to comment Share on other sites More sharing options...
joseph37 Posted June 2, 2012 Author Share Posted June 2, 2012 thank you yojic i thought x337 was the motor not the complete bogie ... istill cannot find any videos on fitting decoder ...once again thankyou joseph. ps. thanks for info on x04 motor Link to comment Share on other sites More sharing options...
davew111 Posted January 6, 2013 Share Posted January 6, 2013 please help newcomer, can a dcc decoder be fitted to the loco supplied with the london 2012 train set . I am an electronics engineer so reply as technical as need be.Thanks Link to comment Share on other sites More sharing options...
rigrun Posted January 6, 2013 Share Posted January 6, 2013 If you follow this link, you may find an installation guide for a similar type of motor to the one used in the London 2012 train set Link to comment Share on other sites More sharing options...
rigrun Posted January 6, 2013 Share Posted January 6, 2013 Sorry hit the post button by mistake, here is the linkhttps://www.hornby.com/hornby-dcc/decoder-installation-guides/ Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 6, 2013 Share Posted January 6, 2013 Hi davew, it seems your London 2012 set is DCC ready, which means it contains a socket with a blanking plug for DC operation and all you have to do is remove this plug and instal a standard 8 pin decoder such as R8249 and you are almost up and running except - you actually need 2 decoders, one for the driver car and one for the trailer in order to operate all of the lights. These should be programmed with the same address, and you may need to program both in the driver car then transfer one to the trailer as decoders don't like being programmed when they can't see a motor load on them. Sorry, couldn't get more technical than that for you as this one is simple I think. If it's not, someone else will correct me for you. Link to comment Share on other sites More sharing options...
davew111 Posted January 6, 2013 Share Posted January 6, 2013 hi thanks for the early reply but the train does not have a socket so I cut the wires as per the hornby installation dcc book and soldered them as per instructions. The train has a printed circuit board fitted which does not appear in any of the installation instructions on other trains. Tried train after fitting decoder but no action. Checked and have 17v ac on the rails ok but no volts on motor ? Link to comment Share on other sites More sharing options...
poliss Posted January 6, 2013 Share Posted January 6, 2013 The DCC Ready is a mistake afaik. Can't find out much about converting it to DCC. They appear to be the Hitachi Javelin Class 395s. Best I could find are these two links.http://www.rmweb.co.uk/community/index.php?/topic/28016-fitting-a-chip-to-a-railroad-javelin/http://www.youtube.com/watch?v=8dC3M6ORQ2M Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 6, 2013 Share Posted January 6, 2013 Wow, that sure is major surgery suggested. I think I would be removing black lacquer and making a narrow cut in offending PCB tracks to achieve the same result, then I could bridge with solder if I ever wanted to put it back. Dave, just keep in mind this simple principle - decoder black and red wires to wheel pickups and orange and grey to motor connections. Removing capacitor across motor will improve performance and you also need to check that motor terminals are isolated from the pickups or resulting short will fry the decoder. You also have the complication of wiring for lights. These use the white and yellow function wires with the blue +ve common. If I remember correctly, white is forward and yellow reverse. Link to comment Share on other sites More sharing options...
