Potrail2378 Posted May 8, 2021 Share Posted May 8, 2021 Hi, my pair of class 142 Pacers (which I recently converted) are quite happily running around my layout. They have both got decoders on the same address - this is ideal, as their directional lights both operate together and they can work independently of each other. However both cab lights come on together, not sure if this is quite prototypical or not. If I did give them different addresses, is there a way that directional lights would work with each other, and would the cab lights run independently? Thanks in advance. Link to comment Share on other sites More sharing options...
Chrissaf Posted May 8, 2021 Share Posted May 8, 2021 What controller? Link to comment Share on other sites More sharing options...
Potrail2378 Posted May 8, 2021 Author Share Posted May 8, 2021 Sorry, Hornby elite. Link to comment Share on other sites More sharing options...
96RAF Posted May 8, 2021 Share Posted May 8, 2021 Elite supports all consisting.It is presumed the cab lights are working from the decoders’ green wire in which case if you run them on separate addresses you can independently have the cab lights on or off.Consisting with depend largely upon the decoders capability. Some only support simple double heading. Some no double heading at all. Then depending upon the sophistication level of consisting supported you may be able to control functions loco by loco. Link to comment Share on other sites More sharing options...
