Daveb3473 Posted June 21, 2021 Share Posted June 21, 2021 Hi. I have two Hornby class 153 both with esu loksound v5 decoders. Excellent models but very jerky at low speeds. I have used the auto setting function which did improve normal speed but low speed is very jerky. Any advice on cv settings welcome as I have tried lube, clean etc. Both models are identical in behaviour. Many thanks. Link to comment Share on other sites More sharing options...
96RAF Posted June 21, 2021 Share Posted June 21, 2021 Discussion on another forum suggests it is due to cogging of the gears, they being of a high ratio. The thread even tried swapping motors for a well known good type but the problem prevailed. Link to comment Share on other sites More sharing options...
jane1707819582 Posted June 21, 2021 Share Posted June 21, 2021 Two cv's are used to control motor characteristics CV 54 and CV 55 .try adjusting cv54 down /up by a value of 5 then check .continue with this until smooth .CV 55 is useful if the motors have flywheels ,again adjust this by a value of 5 up/down until smooth Link to comment Share on other sites More sharing options...
ellocoloco Posted June 21, 2021 Share Posted June 21, 2021 @Daveb3473As RAF suggest this may be a drive train issue. Have you tried running the units on straight DC to see if the problems remains and thus eliminate the Loksound from the equation? Link to comment Share on other sites More sharing options...
Daveb3473 Posted June 21, 2021 Author Share Posted June 21, 2021 Thank you to everyone for their help CV54 set to 5 and CV55 set to 20 has made the jerkiness a lot less pronounced. Not perfect, but the motors I expect are the culprit there! Link to comment Share on other sites More sharing options...
jane1707819582 Posted June 21, 2021 Share Posted June 21, 2021 Dave does the occur when starting or when stopping ?Reducing CV 56 may help Link to comment Share on other sites More sharing options...
Daveb3473 Posted June 21, 2021 Author Share Posted June 21, 2021 It both directions but more noticeable when stopping. Link to comment Share on other sites More sharing options...
jane1707819582 Posted June 21, 2021 Share Posted June 21, 2021 I would suggest leave CV 54 alone and lower CV 55 one at a time see if this gives you the last bit . Link to comment Share on other sites More sharing options...
