Forum-1211528 Posted June 28, 2021 Share Posted June 28, 2021 I am building layout which I can switch between Dcc and DC (NOT RUN AT THE SAME TIME) But I was wondering how to wire points with point motors for switching between the two? Link to comment Share on other sites More sharing options...
Chrissaf Posted June 28, 2021 Share Posted June 28, 2021 Point motors are connected to their own electrical wiring for operation and not connected directly to the power feeding the track, therefore they are independent to what type of power is actually present on the track rails.Is your question actually this question below:My point motors are currently wired to [or planned to wire to] DCC Accessory Decoders and operated via DCC commands issued from my DCC controller.I would like to also have a choice to operate my point motors by traditional DC Analogue methods as well.Is this possible and how can it be done?If the above is actually the question you are asking then yes it can be done. But the 'how' part of the answer is very dependant upon what DCC componentry you are currently using or planning to use. For example, some non Hornby brands of Accessory Decoders have this 'Analogue' override capability built in to their design. The Hornby R8247 Accessory Decoder does not.So if my deduced question is correct, then tell us what products you are currently using [or are planning to use if not yet purchased] to operate your points and confirm the point motor type and brand you are using as well. Link to comment Share on other sites More sharing options...
Forum-1211528 Posted June 28, 2021 Author Share Posted June 28, 2021 I'm gonna use gaugemaster PM1s Link to comment Share on other sites More sharing options...
Chrissaf Posted June 28, 2021 Share Posted June 28, 2021 GM PM1 is just a Solenoid point motor.You haven't answered the question as to how you intend to operate the PM1 when the layout is DCC controlled.The deployment of PM1's raises another question that you haven't given any information on.The PM1 has a very simple change-over switch built in to it to power live frogs on PECO Electrofrog points. That is not an issue if you are using Hornby Insulfrog points as Hornby points will not be using that PM1 switch, but if you intend to use PECO Electrofrog points with full frog power switching for DCC then that could impact how you wire them up for both DCC & DC operation.To get the best available advice, you really need to give us details of all aspects of your plans as requested in my initial reply and confirm whether you intend to use PECO Electrofrogs with frog power switching. Link to comment Share on other sites More sharing options...
Bulleidboy Posted June 28, 2021 Share Posted June 28, 2021 It's much quicker to have your points operated via an On-Off-On (sprung to centre) toggle switch. My layout is DCC and all of my points are Peco Electrofrog and I use Cobalt iP Digital point motors. They are wired for both toggle switch operation and DCC via my Hornby Elite. Why? Just to see how they worked - I never use the DCC method, it takes to long. That's just my personal view. Link to comment Share on other sites More sharing options...
jane1707819582 Posted June 28, 2021 Share Posted June 28, 2021 I'm gonna use gaugemaster PM1s Have a look at the traintech pc2000 accessory decoder this allows both on a single device . Link to comment Share on other sites More sharing options...
morairamike Posted June 28, 2021 Share Posted June 28, 2021 Just wire the points up as a separate entity controlled from a control.panel using on-OFF-on switches or passing contact switches and a CDU. That way you won't have to worry about whether it's DCC or DC you are running. Link to comment Share on other sites More sharing options...
Forum-1211528 Posted June 29, 2021 Author Share Posted June 29, 2021 All track including points are Hornby set track, it’s my first layout. The track is a closed loops, (Essentially all 2 Trakmat layouts Put together) Link to comment Share on other sites More sharing options...
