William-367201 Posted July 9, 2021 Share Posted July 9, 2021 This set runs fine on Dc but will not run slow on Dcc sets off at top speed on step 1 up to now I have tried 4 different decoders in it adjusted the Cv's but it still sets off at top speed any help would be appreciated Thanks in advance Link to comment Share on other sites More sharing options...
96RAF Posted July 9, 2021 Share Posted July 9, 2021 Sounds like DC runaway. Adjust CV29 to disable it. Link to comment Share on other sites More sharing options...
Chrissaf Posted July 9, 2021 Share Posted July 9, 2021 As the Chris Hoy set is 'DCC Ready' thus an Analogue set.Make sure that you are still not using any Hornby DC Analogue track power connector products [R8206 & R602 - this also includes the R8201 link wire] these track power connectors are not compatible with DCC and can cause lost control of DCC fitted locos, particularly Hornby TTS sound ones which are particularly prone.The correct Hornby power track connector products for DCC are R8241 & R8242.You can perform a DIY modification of the R8206, R602 & R8201 products to convert them to be DCC friendly by opening them up and removing the internal suppression capacitor. Link to comment Share on other sites More sharing options...
William-367201 Posted July 9, 2021 Author Share Posted July 9, 2021 I do not use track connectors, all my track is wired with droppers, never had this problem with any other locos [80 plus]. Link to comment Share on other sites More sharing options...
Chrissaf Posted July 9, 2021 Share Posted July 9, 2021 What controller are you using?If it is RailMaster, then there is a well reported issue where newly added locos only have two DCC states, stationary and full speed. If your controller is RM, then this question would have been better placed in the RM forum which would probably have then triggered replies focusing on the RM issue I have just mentioned. If your controller is not RM, then follow Rob's advice and disable 'DC Operation' in CV29. Link to comment Share on other sites More sharing options...
William-367201 Posted July 10, 2021 Author Share Posted July 10, 2021 I have adjusted cv 29 makes no difference also speed Cv's 5and6 to255 and75 still no Link to comment Share on other sites More sharing options...
96RAF Posted July 10, 2021 Share Posted July 10, 2021 Answering some of the questions you have been asked may help us to help you.Controller make and model and revision state, decoder make and model, Cv29 value, etc. Link to comment Share on other sites More sharing options...
William-367201 Posted July 10, 2021 Author Share Posted July 10, 2021 My CONTROLLER is eLink and HP laptop CV 29 is 2 DC turned off Link to comment Share on other sites More sharing options...
96RAF Posted July 10, 2021 Share Posted July 10, 2021 In that case the answer is likely to be as Chris previously pointed out, a well known RM problem. You should delete the loco from the RM roster and relist it. This may have to be done several times. The clue to a successful listing is what numbers do you see at the top of the throttle slider. Post a screen grab. Link to comment Share on other sites More sharing options...
Chrissaf Posted July 10, 2021 Share Posted July 10, 2021 William,Now that you have FINALLY, told us that the controller is an eLink which means RailMaster. Then your reported issue becomes clear to us. What you are reporting is a very common issue that has consistently been reported since the release of version 1.7x RailMaster [which is why your thread has been moved to this RM sub-forum].The issue only seems to affect when adding a newly purchased loco [or new decoder fitted loco] to the RM locomotive roster. It has got nothing to do with decoder CVs and can not be fixed by changing any of them. It is a RailMaster software issue and has to be fixed within the RM application. I strongly advise that you reset your decoder to factory default [write 8 to CV8] so that the RM fix is not compromised by any CV changes in the decoder you may have made.This previous thread saves me re-inventing the wheel in this thread.Railmaster and ESU v5 speed control issue :: Hornby HobbiesPS - Rob posted whilst I was typing Link to comment Share on other sites More sharing options...
