Vqbella Posted July 17, 2021 Share Posted July 17, 2021 Why can I not download RailMaster software from the Hornby site when I click on the download link it try's to connect to with this link http://www.rail-master.com/rm_setup.exe and eventually times out when I run the windows networks diagnostic it says Your computer appears to be correct but the device or resource (www.rail-master is not responding) I am currently using the same laptop to write this so I know I have internet access. Link to comment Share on other sites More sharing options...
Chrissaf Posted July 17, 2021 Share Posted July 17, 2021 This question has come up several times in the last month or so.Are you using Chrome for your browser. There is a known issue with Chrome.See this previous thread.Can't download the Railmaster software - RM_setup :: Hornby HobbiesI use Firefox for my browser on Windows 10 and have no issues downloading the RailMaster set-up file. RM is treated as an 'untrusted' file and many new browsers have aggressive settings that block it's download. If you are not using Chrome [where you can follow the guidance in the above link] you will need to find a similar setting in the browser that you are using. Link to comment Share on other sites More sharing options...
Vqbella Posted July 17, 2021 Author Share Posted July 17, 2021 Hi chris i was trying to download with chrome unistalled chrome and installed firefox still get the same issue ?? Link to comment Share on other sites More sharing options...
westernwill Posted July 17, 2021 Share Posted July 17, 2021 Just ran a test of the download using Microsoft Edge with no problem. And I use Norton which, with the latest release, has not stopped me downloading and registering RM on my new PC. Link to comment Share on other sites More sharing options...
Chrissaf Posted July 17, 2021 Share Posted July 17, 2021 As you had Chrome then you would have been better off following the 'how to download RM' using Chrome workaround that is described in the linked thread.My 'Firefox' might have been tweaked to allow RM download, too long ago to remember. Orthers have also said that they have no issue with using MS Edge for RM download. Link to comment Share on other sites More sharing options...
Vqbella Posted July 17, 2021 Author Share Posted July 17, 2021 When I click on the download link it try's to connect to with this link http://www.rail-master.com/rm_setup.exe and eventually times out when I run the windows networks diagnostic it says Your computer appears to be correct but the device or resource (www.rail-master is not responding) I am currently using the same laptop to write this so I know I have internet access.running Win 10 with windows defender installed and Fire Fox and MS edge both do not allow me to download file Link to comment Share on other sites More sharing options...
Vqbella Posted July 17, 2021 Author Share Posted July 17, 2021 Have used Fire Fox and MS Edge with windows defender all to no avail even if i use the set up disc that i bought with an Hornby E-Link all says that it is not connecting to hornby Link to comment Share on other sites More sharing options...
Chrissaf Posted July 17, 2021 Share Posted July 17, 2021 I use an alternative security application to Windows Defender, so I don't think I am affected by the option setting below as my AV application disables 'Defender' so try turning off this "Check apps and files' option in Windows Defender Security. Link to comment Share on other sites More sharing options...
Chrissaf Posted July 17, 2021 Share Posted July 17, 2021 If you are desperate for the latest RM 1.74.2 file, you can download it from my 'cloud service'. This will download because the RM setup exe file is contained within a ZIP.You will find the download link on Page 1 [4th post down] of the thread linked in my earlier reply above. Link to comment Share on other sites More sharing options...
Vqbella Posted July 17, 2021 Author Share Posted July 17, 2021 Hi Chrissaf thanks for the zip file railmaster is now on my PC but still have the intial problem where i can not register Rail Master have put in a request for support@rail-master.com to look into this again thanks for you help Link to comment Share on other sites More sharing options...
