daveyplod Posted July 23, 2021 Share Posted July 23, 2021 When I start Railmaster and all is loaded and controller initialised, I cannot send any commands to any of my locos. Sound will not turn on nor the locos move. Withe exeption of one loco which runs at c 10 mph with no start command given. Removing this loco from the track means that another loco starts at 10 mph and wont stop until power is off. As far as I know I have the latest software issue and run Pro as well. Link to comment Share on other sites More sharing options...
Chrissaf Posted July 23, 2021 Share Posted July 23, 2021 Which controller interface are you using, eLink or Elite? Link to comment Share on other sites More sharing options...
daveyplod Posted July 23, 2021 Author Share Posted July 23, 2021 elink. Daveyplod Link to comment Share on other sites More sharing options...
Chrissaf Posted July 23, 2021 Share Posted July 23, 2021 Pity that. An Elite has a 'factory reset' option which is not replicated in the eLink unit.This is a long shot or an act of desperation [whichever way you want to look at it] but you could try manually reloading the firmware into the eLink.'How To' instructions.Firstly, RailMaster must not be running.Connect and power up the eLink and open Windows 'Device Manager' to see what COM port has been allocated. It is the X number in "USB Serial Port (ComX).Take a mental note of the X number value.Using Windows File Explorer, navigate to the RailMaster program folder in C:/Program Files (x86)Look for and find the file eLink107.exeRight click this file and choose 'Run as administrator', then follow on screen prompts entering the previously noted ComX number when prompted.This should over-write the installed firmware and return everything to factory settings. Then test for your issue again. Link to comment Share on other sites More sharing options...
pd91223 Posted July 23, 2021 Share Posted July 23, 2021 Has your RM/elink configuration ever worked? What locos are you running with what DCC decoders? Link to comment Share on other sites More sharing options...
daveyplod Posted July 23, 2021 Author Share Posted July 23, 2021 Thanks Chrissaf, I will try tp re load the software.Yes pd9 1223, my configuration has worked for a number of years now. The loco in question is a Bachmann Class 110 2-car DMU with a Loksound 4 decoder. Link to comment Share on other sites More sharing options...
daveyplod Posted July 24, 2021 Author Share Posted July 24, 2021 Well, the reset seems to have worked and all is now well and back to normal. So thanks for the help Chrissaf.Dave A Link to comment Share on other sites More sharing options...
Chrissaf Posted July 24, 2021 Share Posted July 24, 2021 thumbsup Link to comment Share on other sites More sharing options...
