Jon-736062 Posted July 28, 2021 Share Posted July 28, 2021 Hello - I want to buy my first airbrush and compressor kit but don’t know where to start. Any advice? I’m looking at spending £100. Link to comment Share on other sites More sharing options...
Ratch Posted July 28, 2021 Share Posted July 28, 2021 I have moved your post to the Humbrol forum as there are already a number of posts giving advice on airbrushes.Are you looking to spend £100 on just the airbrush or the whole set up (including compressor)?I recommend Iwata airbrushes (if you can get one under £100). Link to comment Share on other sites More sharing options...
DoubleD Posted July 29, 2021 Share Posted July 29, 2021 Jon - I was advised when looking for a kit to get one that has a separate airtank.I purchased one from ebay that was under £100 that also had 2 airbrushes included in the deal - these were not brilliant but got me going until I then purchased a better airbrushThis link shows the type I got - Professional RDG Tank Airbrush Compressor Kit with Air Brush Model AB135/130/138 | eBayGood luckDale Link to comment Share on other sites More sharing options...
peebeep Posted July 29, 2021 Share Posted July 29, 2021 Jon - I was advised when looking for a kit to get one that has a separate airtank. A separate reservoir is best: https://www.ebay.co.uk/itm/132166170957?hash=item1ec5b7b94d:g:ntEAAOSwrAFcNFBf Link to comment Share on other sites More sharing options...
Jon-736062 Posted July 29, 2021 Author Share Posted July 29, 2021 Jon - I was advised when looking for a kit to get one that has a separate airtank.A separate reservoir is best: https://www.ebay.co.uk/itm/132166170957?hash=item1ec5b7b94d:g:ntEAAOSwrAFcNFBfThank you - did it do the job ok? I appreciate that I will need to upgrade the air brush at some point Link to comment Share on other sites More sharing options...
Jon-736062 Posted July 29, 2021 Author Share Posted July 29, 2021 I have moved your post to the Humbrol forum as there are already a number of posts giving advice on airbrushes.Are you looking to spend £100 on just the airbrush or the whole set up (including compressor)?I recommend Iwata airbrushes (if you can get one under £100).Thank you, much appreciated Link to comment Share on other sites More sharing options...
peebeep Posted July 29, 2021 Share Posted July 29, 2021 Thank you - did it do the job ok? I appreciate that I will need to upgrade the air brush at some point In my experience yes, I've been using an AS186 for several years. You can switch it on and let the reservoir fill up, once it's up to pressure it cuts out. Leave it switched on and it will kick in once the pressure dips below what's set on the regulator. The reservoir is not huge, so for an extended amount of spraying it will switch on and off whilst airbrushing, but unless you're using a very high spray pressure and it drops very low this won't be an issue. Essentially, you can switch on at the start of your bench time and only need to switch it off when you're all done for the day. The other benefit is you don't get any pulsing, although this may not be a problem if you're using a reasonably lengthy air line. Link to comment Share on other sites More sharing options...
Jon-736062 Posted July 30, 2021 Author Share Posted July 30, 2021 Thank you - did it do the job ok? I appreciate that I will need to upgrade the air brush at some pointIn my experience yes, I've been using an AS186 for several years. You can switch it on and let the reservoir fill up, once it's up to pressure it cuts out. Leave it switched on and it will kick in once the pressure dips below what's set on the regulator. The reservoir is not huge, so for an extended amount of spraying it will switch on and off whilst airbrushing, but unless you're using a very high spray pressure and it drops very low this won't be an issue. Essentially, you can switch on at the start of your bench time and only need to switch it off when you're all done for the day. The other benefit is you don't get any pulsing, although this may not be a problem if you're using a reasonably lengthy air line.thank you much appreciated Link to comment Share on other sites More sharing options...
