SP1707822544 Posted August 18, 2021 Share Posted August 18, 2021 Hi everyone . I’m surya and new to this forum and the slot car community . I recently bought the Bugatti Supercar set. This happens to be by first slot car set. Yes it’s an older model but these sets are quite expensive here in India . Since, I want to build a longer track , would like to know if the current set can accommodate 2 ultimate extension tracks or would I need to change or add any modules. Your help and support would be really appreciated Link to comment Share on other sites More sharing options...
Andy P. Posted August 19, 2021 Share Posted August 19, 2021 I am not sure I get the question. All Scalextric Sport track is compatible with all other Scalextric Sport track.Your Bugatti set has Sport track.The only exception is if you want to do digital racing:https://uk.scalextric.com/catalogue/sets/digital-sets?encoded=JYxBCgIxDEVv040IVmFwE9x4AMHlMITYxlqs05JkwLm9Vbfvv_9OheZ0IXuABir8NslhuzzdPRdj0fFFcySrsuKf4G2dxiY1LsEwkHHq2wTnnLJR2VzZ1DVKjDmC3_vBaRXrJzg64VAlKrZe-Spw2P1U8B8Which requires a special power base.If you are asking if you need more power then the answer is likely no. Good track in a good condition should not need extra power of anything up to 10 meters... Link to comment Share on other sites More sharing options...
SP1707822544 Posted August 23, 2021 Author Share Posted August 23, 2021 Apologies if I confused you with my question. I will try and rephrase it. The question was can I add 2 ultimate extension tracks to the existing set to increase the racking distance? Would adding the additional track impact the performance? Link to comment Share on other sites More sharing options...
Andy P. Posted August 23, 2021 Share Posted August 23, 2021 Anything under 10 meters should be OK as long as the connectors between the tracks are good. See here for more info:https://uk.scalextric.com/support-and-advice/advice/track-maintenance Link to comment Share on other sites More sharing options...
SP1707822544 Posted August 24, 2021 Author Share Posted August 24, 2021 thank you so much Andy . This is really helpful. Link to comment Share on other sites More sharing options...
Andy P. Posted August 24, 2021 Share Posted August 24, 2021 thumbsup Link to comment Share on other sites More sharing options...
