Potrail2378 Posted September 7, 2021 Share Posted September 7, 2021 Hi, I've just bought a Lima (Hornby?) class 55 Deltic in Porterbrook purple, running number D9016. Because it has triple headlights, I feel obliged to fit three sets of directional lights when I convert it to DCC. Is it a 'high beam' and 'low beam' kind of configuration? And could I utilise the purple feed of the decoder to achieve this? Thanks in advance. Link to comment Share on other sites More sharing options...
96RAF Posted September 7, 2021 Share Posted September 7, 2021 Short answer yes - the white and yellow wires (in concert with the common positive blue) take care of the directional running lights and you could use the green for one end cyclops headlight and the purple for the other end.These would operate thus...F0 - directional, F1 one way and F2 the other way. Link to comment Share on other sites More sharing options...
Potrail2378 Posted September 7, 2021 Author Share Posted September 7, 2021 96RAF - thanks. Another question, if/when I upgrade to a DCC sound decoder (I usually use a class 37 sound decoder), I would only have a green wire to play with, on F25. I also quite like to install cab lights - do Hornby have a decoder with more than four functions? Link to comment Share on other sites More sharing options...
96RAF Posted September 7, 2021 Share Posted September 7, 2021 Short answer is no. Even the Sapphire was only a four function decoder.TTS is a three function decoder, with directional lights using two and F25 using the third. Any cab lights on that function output would not be directional, only both on or off, unless you rigged them from the F0 directional wire, but that would not be prototypical i.e. cab light on when running. Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 9, 2021 Share Posted September 9, 2021 Rob/Chris, given TTS is based on the 8249 design, is the 4th function wire there on the decoder PCB, just no flying lead attached to it?If so, any guidance on where to find it and solder to it to access the function, for those with the skills? Link to comment Share on other sites More sharing options...
96RAF Posted September 9, 2021 Share Posted September 9, 2021 @FishyAlthough the basic architecture of the two decoders is the same they use different PIC chips and the TTS decoder is only rigged for three function outputs (F0 fwd and rev and F1). In simplistic terms the fourth function output has been hived off to feed the sound amplifier.If you compare the TTS and R8249 decoders there is unfortunately no ‘ninth’ pad on TTS to solder a purple wire to. Link to comment Share on other sites More sharing options...
