Rocker1707822558 Posted September 9, 2021 Share Posted September 9, 2021 I just bought a new R3605TTS and I'm finding that it occasionally stops and starts again and sometimes it doesn't even start again and I have to cut the power to get it working again. This only happens at speeds greater than about 50%. It makes no difference if sound or lights are on or off. It seems it starts cutting out after about 10 mins of running with or without hauling loads. My controller is a Select. I also have a Castle Class with TTS and that runs fine. So I guess this is a fault and I should send it back for a replacement, but is there anything I can try or check to fix it? I already checked for loose plugs on the decoder. Link to comment Share on other sites More sharing options...
96RAF Posted September 9, 2021 Share Posted September 9, 2021 It appears to be cutting out on overload of the decoder.When it stops does the Select screen show any abnormality, such as fading in and out as if rebooting continually. Are you using the 1-amp power supply with the Select.As it does this with sound and/or lights on or off it points to a possible fault. I would be tempted to go for a return for replacement. Link to comment Share on other sites More sharing options...
ColinB Posted September 10, 2021 Share Posted September 10, 2021 I suppose before you send it back, check to see if there is a capacitor across the motor, it may be this causing the issue. If it has one remove it. Link to comment Share on other sites More sharing options...
morairamike Posted September 10, 2021 Share Posted September 10, 2021 Possible the chip is not pushed fully into the socket. Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 11, 2021 Share Posted September 11, 2021 As it’s new, removing the capacitor as Colin suggests (Colin, it’s new, it will have a capacitor), may void your warranty. I agree with removing it but not until your sure if you want to use the return warranty or not. I also agree it sounds like an overload, either Select if showing abnormal or decoder if not. Are you running anything else at the time? And please confirm if you are using the 1 Amp supply as already asked by Rob. Link to comment Share on other sites More sharing options...
Rocker1707822558 Posted September 14, 2021 Author Share Posted September 14, 2021 Thanks for the advice. The issue seems to be getting worse and I can't fix it so I'm getting a replacement which should arrive tomorrow. Hopefully, it's a one-off and not a bad batch! Link to comment Share on other sites More sharing options...
