Bulleidboy Posted October 1, 2021 Share Posted October 1, 2021 I am not sure whether this has been asked before, but can any blanking plate be fitted to any loco? I appreciate an eight pin blanking plate will be needed for an eight-pin socket. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 1, 2021 Share Posted October 1, 2021 Not always.Some models require blanking plates with diodes on them to generate a positive feed supply for factory fitted lighting.However, basic motor function should not be impacted by not using the blanking plate designed for the model, as motor function is the lowest common denominator requried function support.If you then fit a blanking plate with lighting diodes into a model that deals with the generation of a positive supply away from the blanking plate and on a main loco PCB where factory fitted and doesn't require a diode equipped blanking plate, then the lighting function may be affected. One would need to see the circuit diagram of the loco PCB to make a proper assessment of suitability. Link to comment Share on other sites More sharing options...
Bulleidboy Posted October 1, 2021 Author Share Posted October 1, 2021 Thanks for the quick response Chris. It is not a problem I have, as I said, I keep all of the blanking plates removed by me. I have seen a number for sale on Ebay which say "blanking plate for a Class whatever", and wondered if they were "model sensitive" - the reasons which "may" affect a loco, you have explained clearly. BB Link to comment Share on other sites More sharing options...
Chrissaf Posted October 1, 2021 Share Posted October 1, 2021 I believe the Class 43 or HST models are the ones that most commonly have their own specific blanking plates. Link to comment Share on other sites More sharing options...
96RAF Posted October 2, 2021 Share Posted October 2, 2021 General blanking plate. Right hand one rigged for lights.Blanking plate with diodes. Link to comment Share on other sites More sharing options...
