Macca1707822211 Posted October 24, 2021 Share Posted October 24, 2021 HelloCan you please help a confused 78 year old. I am looking for a connection wire for a DCC train set to connect my Hornby Select to the power track. The one that came with the train set has got lost in a house move. I have searched the Hornby web site and I cannot find the part number for the connection wire I need. Thank you. John McAdam Link to comment Share on other sites More sharing options...
RDS Posted October 24, 2021 Share Posted October 24, 2021 If it is just the wire you need, any 2 core wire will suffice. A lot of people use Speaker wire.If it is the Track connector you require, R8241 is the Hornby Part number for the Digital version. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 24, 2021 Share Posted October 24, 2021 The connection wire is not sold as a separate item. The Select uses spring terminals as its output connectors, which means that any general purpose wire can be used. General purpose 'Figure 8' (also termed shotgun cable) speaker wire is ideally suited for this purpose. This type of wire terminates easily under the spring terminals on the Select. At the track power connector end, the wire can be terminated with Hornby X8011 terminals, which then push into the wire receptacles on the track connector. Currently out of stock in the Hornby shop, the X8011 terminals are readily available in some model railway shops and on ebay. The X8011 would normally be soldered onto the wires, but optionally can be 'crimped' by those who do not want to solder. Link to comment Share on other sites More sharing options...
Macca1707822211 Posted October 25, 2021 Author Share Posted October 25, 2021 Thank you for your prompt replies. I have ordered some 2 core speaker wire from Mr Amazon. The man next door is a retired electrician and he is going to fix it up for me. Thank you once again. Link to comment Share on other sites More sharing options...
