Simon123 Posted June 25, 2012 Share Posted June 25, 2012 I have a Hornby Class 31 with sound, but I cannot turn the sound off. The only way I can "shut it up" is to remove it from the track! How can I reset this? I have other locos with sound and I have no problems. I use a Select controller. Thanks Link to comment Share on other sites More sharing options...
poliss Posted June 25, 2012 Share Posted June 25, 2012 See the section in the Select manual entitled 'Locomotive Function Control'. Go to the sub-heading 'Controlling locomotive functions'. Where it says "Press and hold Function+2" substitute the '2' for '1'. According to the decoder manual F1 controls the on/off sound function. Link to comment Share on other sites More sharing options...
Simon123 Posted June 26, 2012 Author Share Posted June 26, 2012 poliss said: See the section in the Select manual entitled 'Locomotive Function Control'. Go to the sub-heading 'Controlling locomotive functions'. Where it says "Press and hold Function+2" substitute the '2' for '1'. According to the decoder manual F1 controls the on/off sound function. Link to comment Share on other sites More sharing options...
Simon123 Posted June 26, 2012 Author Share Posted June 26, 2012 thanks for that, however pressing the Function 1 key doesn't turn it off. It seems to be stuck in an acceleration mode and I think it needs resetting! Link to comment Share on other sites More sharing options...
poliss Posted June 26, 2012 Share Posted June 26, 2012 You can't reset decoders with the Select. You would need the Elite to do that. Maybe your local model shop could help. Link to comment Share on other sites More sharing options...
Simon123 Posted June 26, 2012 Author Share Posted June 26, 2012 poliss said: You can't reset decoders with the Select. You would need the Elite to do that. Maybe your local model shop could help. Link to comment Share on other sites More sharing options...
Simon123 Posted June 26, 2012 Author Share Posted June 26, 2012 ok cheers, my local shop has an Elite so I will take it back to him. i didnt want to bother him if it was easy, but he gets my hard earned money.......... thanks!! Link to comment Share on other sites More sharing options...
olly Posted July 3, 2012 Share Posted July 3, 2012 simon123 try running the class 31 on dc analog and it should reset with the sound off when it's on dcc Link to comment Share on other sites More sharing options...
poliss Posted July 3, 2012 Share Posted July 3, 2012 Why would it reset the sound to off olly? Link to comment Share on other sites More sharing options...
olly Posted July 4, 2012 Share Posted July 4, 2012 poliss said: Why would it reset the sound to off olly? I did the same thing with my hornby sound class 56 and running it on DC solved the problem Link to comment Share on other sites More sharing options...
poliss Posted July 5, 2012 Share Posted July 5, 2012 It shouldn't have. CV settings should remain the same when run on DC. What controller do you use? Link to comment Share on other sites More sharing options...
olly Posted July 5, 2012 Share Posted July 5, 2012 poliss said: It shouldn't have. CV settings should remain the same when run on DC. What controller do you use? I use a hornby select for DCC and a hornby hm2000 for DC. Link to comment Share on other sites More sharing options...
poliss Posted July 5, 2012 Share Posted July 5, 2012 The feedback feature of the HM2000 might be what resets the decoder. Link to comment Share on other sites More sharing options...
