Potrail2378 Posted November 28, 2021 Share Posted November 28, 2021 Hi. As per the title, I would like to know if I am able to dim the headlights on my loco's by altering any CV numbers. I usually install 3vDC LEDs with a 1Kohm resistor in series for each LED. The lights look great on the layout, but are far too bright when being photographed or videoed. Any help would be much appreciated. Link to comment Share on other sites More sharing options...
96RAF Posted November 28, 2021 Share Posted November 28, 2021 That would depend upon the loco decoder. Some have the facility, many don’t. You need to check your decoder ‘user manual’. Link to comment Share on other sites More sharing options...
Chrissaf Posted November 28, 2021 Share Posted November 28, 2021 Dim the LEDs by increasing the value of the resistors. The final value will need to be arrived at through experimentation. Start with a 4.7K resistor value and go up in approx 1K steps to an expected maximum of 10K.At a guess, I would anticipate a value around 6.8K will give a sufficiently dimmed effect.As Rob says, very few brands of decoder give the ability to dim LEDs through CV adjustment. Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 28, 2021 Share Posted November 28, 2021 Chris’s and Rob’s solutions are (semi) permanent but the OP is looking for a temporary one during photography. Given they are running lights, keeping them synched to direction would be a problem, but what’s the practicality of connecting them to a second CV including a higher value resistor, just for the photography? Turn off Running lights, turn on photo dim. Link to comment Share on other sites More sharing options...
Potrail2378 Posted November 29, 2021 Author Share Posted November 29, 2021 Hi, and thanks for the answers so far. One particular loco is a Hornby Yeoman class 59 Kenneth J Painter which has a sound decoder fitted. I have put a headlight kit in, which I bought off eBay, but I also installed a headlight below the windscreen which is a bit too bright for the camera. Link to comment Share on other sites More sharing options...
