Class421 Posted July 3, 2012 Share Posted July 3, 2012 I have just converted to DCC operation and I've come up with a few problems 1. One of my locos initially worked (moved fwd and backwards slowly and all the lights came on and off). However, when I set it going for a lap round the track, it just shot off had top speed and there is nothing I can do to stop it except press 'stop'. Lights no longer function and I can't change direction. 2. Some loco's moving at slower speeds (1/4) over the points cause a short and the controller trips. Its mainly with my margate locos but the new HST does it as well. I have a mixture of new p*co, R8072/3 and R612/3. 3. My triang locos used to stall very momentarily on points when running on DC, but now they slide almost to a stop before restarting, well away from the point. I take it this is possibly a CV issue? Any help would be much appreciated as it is giving me a bit of a headache! Link to comment Share on other sites More sharing options...
poliss Posted July 3, 2012 Share Posted July 3, 2012 1) Sounds like a blown decoder. If you have the Elite you could try turning off DC in CV29. 2) Check the back to back distance between the wheels. Should be 14.4mm. 3) Tri-ang locos don't have pick-ups on all wheels meaning they lose power on insulfrog points. Solution. Use electrofrog points. Link to comment Share on other sites More sharing options...
Icurus Posted July 3, 2012 Share Posted July 3, 2012 What DCC controller and decoder are you using? I used A select and I had a similar problem with TCS decoders. Upgrading to an Elite solved the problem for me. Link to comment Share on other sites More sharing options...
Class421 Posted July 3, 2012 Author Share Posted July 3, 2012 Thanks for the advice, the loco which just shot off is behaving itself now and i will attempt to follow your advice in the morning Link to comment Share on other sites More sharing options...
poliss Posted July 3, 2012 Share Posted July 3, 2012 Ah, then it could have been a simple short circuit that caused the loco to run away. See http://www.tonystrains.com/tonystips/2011/032211.htm for an explanation. Link to comment Share on other sites More sharing options...
